  • Replies 73
nah thats only used for going too and from workshops... if i get pulled over or the car is seen out and about at a public meeting i will get reemed.
that the rule for a UVP? How strict is this? Can you just say you're heading to a workshop and flash a quote for something?
https://www.sau.com.au/forums/topic/49465-the-beast/page/4/#findComment-990876
yeah... as long as ur taking the shortest route to the workshop from your house (as thats they ask you where it is kept and where it will be driven from) or vice versa then ur ok...
https://www.sau.com.au/forums/topic/49465-the-beast/page/4/#findComment-990880
    • If your head gasket lifted, you should have seen a coolant pressure spike. There's no need for a copper gasket/fire rings at 30psi. An MLS with perfectly clean/flat mating surfaces should suffice.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
