  • Replies 52
Hehe dont like to laugh at your mis-fortune but god damn thats funny...mainly due to commentry..... who was driving with Joe?
I didnt realise that happened in Armadale.....thats corner is like 1min away from my house...cool :) Also its Albany Highway not Armadale road like you say in the video (yeah i know no one likes a smartass)
Ben
@#$%^&*(!!!!!!!:flamed:
Hehe yeh bad case indeed, if ure sitting at the lights the corner looks more cornery and not so straight if u catch my meaning. I was thinkin it was a long swweping corner then alluva sudden im sideways on a straight road:eek: hmm mostly bad drivin though:lol:
hehe yeah... i was just winding you up man. actually that corner has a few bumps in it too. that wouldnt have helped.
anyways i dont exactly have a clean track record when it comes to 180ing it off the road on a cruise :) (read mandurah cruise) lucky for me all i hit was a heap of grass.
Originally posted by Boostzor
Yeh Ken thats y I got the full comp:D  Nahh seriously i wnated to let it go savage at MC hey i gotta learn somehow it might as well be somewhere im not gonna hurt any1 or the car. Plus i do not accept blame for the first incident that was total BS coulda happend to any1. The one u see here though ahh... yeh well cant blame any1 for that now can i :) At least after those 2 i never drive like a nutter on the road (used to cain it like a man possesed) i have gained a measure of 'self control' too bad that doesnt extend to "car control" :)
If anything it tells me im not as l337 as i thought. I apologise for not being as l337 as you Ken :(  Im sure u had ure share if run ins in ure time.:) *ahem*GTR*cough*targa*splutter*write off:)
1337 Huh !! whats that.
My share, f**cken oath. I trashed a few in the early days , but always in competition , not on the road.
Have destroyed a Datto(1600)
Murdered a Mazda ( RX7 )
and heaven forbid
Screwed a Skyline ( GTR )
but I'm getting better at it . Driving , not crashing , that is
Ken
Originally posted by adam 32
i cant afford the insurance on my car so have 3rd party fire n theft from Suncorp Meway. costs me $252 a year, and in the event of an accident it covers everything (car and property) except for my own car. i personally think thats the way to go if you are unable to pay $2000 a year or more for insurance.
once im 21 im gunah try again, ive never had an accident so hopefully in 2 years time ill get a decent quote on insurance....
hey adam, im chasing insurance quotes at the moment, called Suncorp up, they said they dont do any under 21's. How is this so, is your insured under parents name without u being nominated as a driver?
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
