just finished runnung in rb30det in r33. done the 1000 kms then wound boost to 1 bar. blowing smoke great!!! comp test ... 70 psi in number 3 and 110 in the rest of the cylinders. done leak done test and its blowing past the rings. a fews days later and a couple a hundred ks more and comp getting to 90. thought ide try a couple of hundred more. so at 1,400 kms done a comp test tonite to show only 70 again. brought those f...kin acl pistons and rings 4 rb30 non turbo. will pull it down tomorrow to see whats going on. where can i get some forged pistons and do it properly this time and how much. does anyone know what comp it should have with these pistons. oh yeah would do a search for these questions but havent got all night to sort through the chit chat.
cheers dave.
https://www.sau.com.au/forums/topic/49783-rb30det-just-run-in-low-comp-no3/
ACL rings? I hear very bad thing about these (only in RB engines so far), they just dont bed in properly. I'm betting if you pull it down you'll still be able to see the hone pattern on the cylinder wall.
-rb25
my rb30 bottom end still showed hone marks on the bore and it had done near 400,000 kms in a vl before i got it.
             cheers  dave.
What oil did you run it in on? They all sound a little light on compression, but a compression test is not an exact science. A leak down test would be much better and far less likely to give random results.
I have a spare set of brand new forged 87.5 mm JE pistons with Total Seal rings, ceramic top coated, oil retention skirt coated, they are balanced and ready to go. PM me if you are interested. :cheers:
you cant hone a bore properly with a ball hone, they wont break the glaze, you need a decent fixed hone with some 500 grade stones, possibly followed by finishing stones to plattoe hone the pattern. I would have done a wet comp test to see if that made a big difference to your low cylinder that way you rule out valves, is your inlet cam timing correct as well cause that will bleed off compression and make them low overall.
  • 3 weeks later...
ok, a question for all u guys saying to use total seal rings...
Total seal rings, how are they better?
just out of "interest" to extend my knowledge a bit more on the "pro" side of them...
As you mention them down here in vic and a lot of people go green in the face at the thought of using em.
it appears to have been running lean. when i got the injectors cleaned b4 use they told me two werent pulsing. even though they were ok when they came out. when he went to show me that they were not working they had come good. he said maybe because they were in the bath ova nite. or i also put xf throttle body with closest t.p.s i could find, it was very close to original but n.q.r. but i dont think this would be a problem. just needed more fuel i think. there was no pinging or any signs like that. i kills me to say it but a good dyno may have saved the engine. ive gotta get some injectors b4 it goes on the road again. im thinking sard 550cc cos greenline have a special at the moment. anyone seen any cheaper? they also have 850cc for the same price but it may be ovakill. rb30det, cooler, t3/t4 hybrid. custom plenum.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
