They're going out of business becaue no-one likes to pay for games. Y'all just want to download everything for free. Don't get me wrong it's great to be able to download the games for nothing but, if you like them, buy them.
Richard
https://www.sau.com.au/forums/topic/49818-juiced/page/2/#findComment-1027435
  • 4 weeks later...
Nice conection there, but its on xbox. There needs to be a pc version, its not out yet, suprnova does have torents for the ellusive pc version is not there, in conclusion.... dam you funkymonkey
EDITED: Skyzer
anyone that wants any info on getting this game like the monkey which is funky here are the links to places to accually DOWNLOAD THE GAME
bit torrent client (needed for download you dummy)
www.shareaza.com
Bit torrent site.
Once you have shareaza installed simple go to the following site, there all good as gravy
www.suprnova.org
www.torrenreactor.net
www.bitgoogle.com (might not work)
and then find the game, and using shareaza anti martin technology(it means its good)
it then loads the torren (dat file) and it downloads !!, the downloads start of slow as they should, then they go pretty fast pending on how many sources there are, if its a new game that everyone wants then you will get it in no time.
in conclusion.... there is no conlcusion.
Thanks 4 that i was using an old Bit Torrent downloader and wasnt getting jack, hopefully now i can d/l again! Luv getting Dave Chappelle show and Will and Grace eps. Cheers!
https://www.sau.com.au/forums/topic/49818-juiced/page/2/#findComment-1083494
Oh BTW played a bit of Juiced and totally agree top game, gives NFS: UG a run for its money!!
My fav paint:
Base: X25 Y9
Metalic: X14 Y9 (+75%)
Pearlesent: X34 Y13 (+80%)
Try it u wont be disappointed!!
How do u guys play online, do u have a switch to turn ur xbox chip off? Can u just plug ur xbox in with the same cord u use for ur modem or cable connection that goes to the pc?
Cheers
https://www.sau.com.au/forums/topic/49818-juiced/page/2/#findComment-1083499
i personally dont play online, but yes i do have a switch so i can simply turn my chip off.
To play online you need to register with XBOX LIVE and just network your xbox to your broadband connection... possibly through an interface hub or switch... or you can rip it out of your PC every time you want to play online
https://www.sau.com.au/forums/topic/49818-juiced/page/2/#findComment-1083681
yea, costs a little extra ($10-20) but its worth it in my opinion because xbox live wont run with a mod chip on unless you get new software of something like that.
Its basically just a switch at the back where the plugs are.
What i like bout the Chip is that you can customise backgrounds (i got Jessica Alba :(), startups and even install emulators n stuff
https://www.sau.com.au/forums/topic/49818-juiced/page/2/#findComment-1092984
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
