PM me if you want a custom one designed & made up for you.
I'm an Industrial Designer linked with a carbon/glass/kevlar fibre company. But we need a straight bonnet to rip a mould off first before we can start modifying it. Or just make a standard one in FRP.
Oh, & I just noticed you are in Melbourne. We're in Sydney which is a bit more hassle.
Ben
https://www.sau.com.au/forums/topic/50028-carbon-bonnet/#findComment-995600
www.customcarbon.com.au
Quality is good ,prices are reasonable....do not confuse these with those from UAS,Carmate etc. These are a carbon fibre foam sandwich construction and are 1/2 the weight and 10times as strong.
https://www.sau.com.au/forums/topic/50028-carbon-bonnet/#findComment-995790
Ben
i'll donate my bonnet for experimentation, for a freebie in return :cheers:
https://www.sau.com.au/forums/topic/50028-carbon-bonnet/#findComment-995890
I am currently in the process of getting a www.customcarbon.com.au bonnet as we speak. It is genuine custom carbonfibre item, only 6mm thick and around 6Kg light I'm told(R33 gts-t bonnet 27kg). If you want to see it i'll have it on my car just before my car enters with the SAU stand @ autosalon in melb, sept 18-19.
there a little more expensive than the UAS & carmate bonnets, but thats because there the real deal, not just a carbon top layer with fibreglass under. Plus if your like me, with a series 1 R33, then theres only one (UAS & carmate) vented bonnet style, which I dont really like. so custom was the only choise for me :cheers:
https://www.sau.com.au/forums/topic/50028-carbon-bonnet/#findComment-995996
Ben
Ooooo! You live in Leichhardt, like me! :cheers:
What is the name of the business you work for and where is it located? I might be looking to have some C/F bit fabricated in the future/
Lucien.
https://www.sau.com.au/forums/topic/50028-carbon-bonnet/#findComment-996005
Lucien,
Its a very new company called Sweet out at Penrith. They have done a few things like bumpers/bars, engine covers, air scoops, some std bonnets & a bike fairing. The owner has been working with FRP for years & recently turned his skills towards cars.
They are currnently doing their first full custom bonnet for a guy who is entering his car in Autosalon so hopefully their work will be on display there.
Will post up full details when I've got them to organise advertising and so forth in a couple of weeks.
Ben
https://www.sau.com.au/forums/topic/50028-carbon-bonnet/#findComment-996650
there a little more expensive than the UAS & carmate bonnets, but thats because there the real deal, not just a carbon top layer with fibreglass under. Plus if your like me, with a series 1 R33, then theres only one (UAS & carmate) vented bonnet style, which I dont really like.    so custom was the only choise for me :P
Are you getting one like the pic in thr gallery of the r33?
If so, it looks rather plain compares to the UAS and Carmate ones
https://www.sau.com.au/forums/topic/50028-carbon-bonnet/#findComment-997590
same vented bonnet as in there gallery, with extra vents behind radiator for cooling (kinda like the VeilSide bonnet). As far as looks go....yeah i guess its a little plain, but its the real deal and different.
Plus as mentioned earlier......only 2 choices for SERIES 1 in jap (carbon top fibreglass under) carbon bonnets, plain with no vents, or butt ugly raised vents right at the front of the bonnet. no thanks, not my taste.
The second one mentioned looks ok in the pic on UAS, but seen on an actual car..........
anyway, each to their own, I like to have a few things a little different from the norm. I'll be sure to post some pics whens its on....maybe even a poll? hehe :rofl: or let me know your thoughts at MAS
cheers
https://www.sau.com.au/forums/topic/50028-carbon-bonnet/#findComment-999308
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
