hey guys, im able to get some superlow king springs at a very good price at the moment, i already have lowered suspension on my car but i want to go lower.
does anyone have a pic of an R33 with superlow king springs?
there wont be any point in getting them if they arent much lower than the ones i have on now.
so if you have any pics at all please post them so i know how low they will drop an R33.
or even if you know they roughly how low would look good, e.g. slammed, not very low etc.
https://www.sau.com.au/forums/topic/50049-pics-of-king-springs/
Measure from the centre of the wheels to the guard vertically on your car (on a flat surface is best) and then give Kings a call and ask them what their Superlow springs measurements are. Then you will know how much (if any) lower they are than what you have now. If Kings don't know give Whiteline a call, they will be able to tell you what measurements their springs are.
Hope that helps :cheers:
i already have lowered springs on , but i dont know what brand or how low they are, so i cant tell.
Measure from the centre of the wheels to the guard vertically on your car, should be around 350 mm.
you are doing yourself a disservice just going for the lowest springs for looks, as the spring rate may not be as optimal when the springs are shorter.. again, sorry to beat the drum but there is some great info on the whiteline site on all this:
http://www.whiteline.com.au/faqsprings.htm
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
