Hey blx and funkymonkey,
If you are in need of a service or upgrades to your car, give us a call at Ice Performance.
We're located in Dissik St, Cheltenham (all the details are in the signature).
We've service and modded many Skylines (GTS-GTRs).
Cheers.
https://www.sau.com.au/forums/topic/5008-skyline-servicing/#findComment-77980
mad... i'm jus thinkin of taking it in to change oils n just to give it a general checkup, hasn't had one since july when it was compliance, and even then it was with JSV, god knows what they did.
I'll contact you sometime next week to arrange a time. PM me cost of general service/oil change if you can.
Thanks heaps
https://www.sau.com.au/forums/topic/5008-skyline-servicing/#findComment-78156
Originally posted by funkymonkey
aw crap... this is what I hate... alternatives... well the Thommo one's closer... guess it comes down to price now. I have heard good things bout ICE tho hmmmmm
And ive heard, and been part of very bad things with manuel. My personal opinion is not to go there.
Im taking mine to ice :)
https://www.sau.com.au/forums/topic/5008-skyline-servicing/#findComment-78239
funkymonkey, u should just do the oil change urself. doesn't take long at all and will save u a shiat load of money. buy some decent oil and change it urself every 5000 or so k's. and then wen its due for the major service take it somewhere.
else some places charge like $75 just for oil change and inspection. not worth it.
https://www.sau.com.au/forums/topic/5008-skyline-servicing/#findComment-79108
anyone wanna tell me how to do it, which oils to change etc? I've always jus fanged it into my favourite service centa (which used to be tuffy's down the block from my house in Epping, NSW, here I dunno anyone.
Anyways, I don't have a garage, so if its too messy n complicated i wouldn't be able to do it. I could get a pan n stuff to drain it I guess.
What do I check every 5000k's n how? it sez on the japanese service manual but i can't read kanji.
Its for a 2.0L N/A r32... I'll probably pop into ICE once I hit 10k coz I really want sumone to give it a thorough check, right now it just needs a minor checkup.
https://www.sau.com.au/forums/topic/5008-skyline-servicing/#findComment-79160
Change oil every 5k no matter what is a good rule to go by. Most ppl use mobil one but there are always alternatives eg insanely expensive royal purple etc etc.
I change my own oil but im not sure hwat actaully happens in a 'major service' any1 knows what actaully gets done plz make a list:D
https://www.sau.com.au/forums/topic/5008-skyline-servicing/#findComment-79179
hey funkymonkey, its real easy, i just did it yesterday and i'm really no mechanic and not good at that sort of stuff, so anyone can do it.
go out and buy some engine oil, (best if u buy it on sale from k-mart or supercheapauto or something like that, u save quite a few bucks) buy the oil filter from autobarn z145a $10.
then let the car cool down a bit and just jack her up and drain the oil and pour the new one in. mite want to let the car down again wen ur draining the oil so that more of it comes out.
check ur oil, its prolly quite black by now if u haven't changed it in a while.
all up cost about $30. cost me around $20 for mobil S (semi synthetic, on sale from k-mart :D ) and $10 for ryco oil filter.
https://www.sau.com.au/forums/topic/5008-skyline-servicing/#findComment-79239
The ryco filters are pretty crappy and i think the authentic nissan filters are cheaper anyhow.
If u havent done it in a while u might also wanna think about buyin a bottle of oil flusher (think thats what the call it) loosens up all the oil so i drains better but it can also mean that u lose all that nice sticky stuff protecting ure engine.
https://www.sau.com.au/forums/topic/5008-skyline-servicing/#findComment-79265
A service once every 5k keeps the mechanic away...
For me and a few mates this is what we do :
5k intervals
Engine Oil with new oil filter
Gearbox Oil
Oil and Clean Pod Filter
Computer Reset (on thos with the stand ECU)
Inspection of pads/rotors/fluids/belts
10k
as above with
brake bleed
new fuel filter
flush radiator
compression test (helps when you mate is mech with all the good tools)
20k
as above again, but adding new spark plugs, new air filter element , brake pads usually
The Nissan 100k is pretty big and needs a workshop
all the above and :
change of all belts, water pump, alternator (?)...not to bad on the 'Lines as they have a timing belt...****ED if your doing it on a SR which has the chain...gggggggrrrrrrrrrrrrrrrrrrr...
https://www.sau.com.au/forums/topic/5008-skyline-servicing/#findComment-79423
Thanks for the help guys..
I have another problem that i hope you can help me with..
One of my fan belts is half the original size (width ways) parts of it are shredding off and I desperately need a new one but no one seems to know the part number.
The belt is (as you look at the engine from the front) the bottom one on the right hand side.
If any one has any idea on the part number please email the email address below.....thanks.
https://www.sau.com.au/forums/topic/5008-skyline-servicing/#findComment-80296
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
