  • Replies 59
Mad Wagon. Did you get your RSM sorted out? Do you find that it gets in the way where it is? I have bought one to go on my car when I get it. Can you let me know what the problem was when you find out please? Oh and by the way what size are your rims? I have some 18X9 rear and 18X8 front ones I got in from Ozzy Tyres. The guy said they would fit. I'm starting to think they may not.
https://www.sau.com.au/forums/topic/50201-photos/page/3/#findComment-1021771
__________________
hey burkey22,
just fitted r33gtr(17'-9 +30offset) rims today.... they do sorta fit.. but stick out a little bit.
best fittment for stagea rs-four 17" or 18"-8 +30offset ( tested n proven )
https://www.sau.com.au/forums/topic/50201-photos/page/3/#findComment-1022594
I was talking to a mate of mine in Japan because we're looking for TE37s and he came back with this:
> I called the parts shop to specify the parts about Rays Volk TE37 Size is
> 17x8.5 30/40
> They told me this alloy has 2 types. they are 30/40
> If that Stagea is customized as low-down, the wheel size suppose to be
> 17x8.5 30/. However the alloy may scratch the fender of the car.
> If that Stagea is not customized, the wheel size suppose to be 17x8.5 40/
> However it may scratch the inner of the car
> The Parts shop adviced me that Ray Volk TE37 has other types.
> They are 17x8J 33/38 33 is for low down and 38 is for normal car.
https://www.sau.com.au/forums/topic/50201-photos/page/3/#findComment-1036711
One point of advice I was given when i got mine was just like the GTR u should keep the same rubber front and rear or they scrub out coz of the 4wd.  GTR offset seems to be +40.
Keeping the same diameter front and rear is correct, but width is irrelevant. :)
https://www.sau.com.au/forums/topic/50201-photos/page/3/#findComment-1036868
Thanks for the tip, so same size would be better for rotational purposes only and not so much scrubbing out problem, cheers.
Scrubbing out? That's more of a term I would apply to poor wheel alignment, not different size tyres on a 4wd. Having different diameter tyres on a Stagea will not scrub out tyres, but it will accelerate wear on the ATTESSA 4wd clutches.
Basically what you are looking for is the same rolling diameter of tyres, so;
245/40/17
205/55/16
225/50/16
225/45/17
245/45/16
all have basically the same rolling diameter ~630 mm
An example, if you have say 7.5 X 17 on the front, then 225/45/17 would be OK with 8.5 X 17 on the rear with 245/40/17.
You need to check with your tyre supplier, as diameters vary between brands.
Hope that helps :(
https://www.sau.com.au/forums/topic/50201-photos/page/3/#findComment-1038006
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
