At the moment wanting to buy a 32 for my first car, but theres this thought thats always pushing to the back of my head.... THE PETROL... and when your pumpin turbo through 6 cylinders; tends to drink a bit. But then i remebered some article that was on a current affairs or today tonight or somethin, about some way that you can make your own petrol out of the left over oil that fish and chip deep fryers??? apprently its really healthy.... but i don't know how true that is.. but this thing on TV was aggggggggggesssssss ago. does anybody know anything about this process???
https://www.sau.com.au/forums/topic/50205-homemade-petrol/
If your impending fuel bill is what's worrying you maybe you aren't prepared for the true cost of owning a Skyline? They are essentially a black hole for money, fuel bills, mods, detailing, servicing - then you'll want to upgrade to a GTR and AARRRGGGHHH!!!!
hehehe but its the best hobby you can have.
https://www.sau.com.au/forums/topic/50205-homemade-petrol/#findComment-998529
If your impending fuel bill is what's worrying you maybe you aren't prepared for the true cost of owning a Skyline? .....
nah its not that bad, i know the skylines gonna cost me more than your av car but hey ill find the money, actually the situation isn't that bad , just thought it was worth looking at cos free fuel would be pretty damn cool... guess it was too good to be true then..
https://www.sau.com.au/forums/topic/50205-homemade-petrol/#findComment-999550
funny that you say that, cause Optimax is supposed to be a shit fuel.
maybe you should stick to the home made stuff :rofl:
Hmm looks like we had a petrochemical expert here with his own lab and everything.
I wouldnt mind knowing the molecular makeup of optimax when you have some spare time
note: this post is very sarcastic.
https://www.sau.com.au/forums/topic/50205-homemade-petrol/#findComment-999571
whic is?....
One thing, RB engines dont run on diesel.
It is made by chemically reacting vegetable oils, animal fats with alcohol and recycled cooking grease/oil. Some bio-diesel is made from domestically produced soybean oil.
It can be made from both new and used vegie oil and animal fats. The fat is chemically reacted with an alcahol ( usually methanol ) to make whats called fatty acid methyl esters. Glycerol is made as a coproduct.
The oils and fats are filtered and preprocessed first to remove water and and contaminants. They are then mixed with the methanol and a catalyst ( sodium or potassium hydroxide ).
The molecules are are broken apart and then reformed into esters and glycerol which are seperated from each other and purified
I dont think you can run an engine straight of bio-diesel. It comes in blends.
B2 is (98% diesel and 2% bio-diesel)
B5 is (95% diesel and 5% bio-diesel)
there are also blends which have 20% bio-diesel (B20)
At the service station ( it still has a fair while before it fully spreads throughout australia ) it would cost around 1.5 times more than straight diesel.
It also has an energy content which is 10% lower than straight diesel. The more you add the less power, torque your engine produces.
Bio-diesel also reduces wear and a mild solvent will clean your fuel system.
https://www.sau.com.au/forums/topic/50205-homemade-petrol/#findComment-999573
I have an issue of "modern MOTOR (may 1974)" – the height of the fuel crisis - which has a formula for making your own petrol. It consists of a blend of :
Toluene (65%)
Benzol (25%)
Naptha (10%) - Heavy naptha, water-white)
Mix the ingredients (by volume) stir and poor in the tank through a strainer (you can get sediment from the naptha occasionally)
This mix is compatible with existing fuel and can be run on its own or in a blend.
This mix was tested on various cars of the day and "they all performed better and gave better economy .. than on either standard or premium octane petrol" - **I would be interested to know the octane rating of this mix, but I guess it must be in the mid nineties**
The article went on to say "we tested this petrol substitute in many vehicles without experiencing any trouble or damage to engine or any other vehicle components." but then went on to say "we accept no responsibility for any damage that might occur" (which makes sense to cover their own backs.
https://www.sau.com.au/forums/topic/50205-homemade-petrol/#findComment-999723
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
