  • Replies 250
I'm going to cry if mine doesn't make it on to the ship that is arriving in december, I will speak to the shop today and find out how thye work over the december period and stuff
WHY IS NOTHING EVER EASY! god damn new cars, aren't the lots full! I drive past and think they can't have sold anything as there isn't anymore space to put cars on the lots
mark
(sorry, getting quite upset now as I wanted to drive it by xmas, it was my present to myself this year)
Guys
I imported a Soarer around Christmas 2 years ago and had heaps of probs including the Front whee falling off. The tyre joint stuffed up the front wheel nuts and it came off whilst on the way to the exhaust shop.
They ended up paying for all the repairs :D but it took 7 weeks to see the car on the road.
I m now in the process of importing a R32 GTST Type M and its missed the boat. :boohoo:
Oh well its to be expected. You would have thought I would have learnt the first time.
Cheers
I have spoken to my compliancer and they said they don't close down over xmas, so if the car gets here he said it will be in and out in a week including fitting the few mods I have
so thats some good news, hope fully its in on the next boat
They would be silly to close at that time with the amount of 15 year cars coming in at the moment. They'd only be doing themselves out of heavy business.
There would be thousands sitting over there in Japan, and that have recently landed.
Hello To you all, heres my update.. some 6 pages ago and back on 1/8 i was trying to find out times on import approval everyone saying 4-6 weeks.. well Guess what today was my lucky day! Finally.. ive been allowed to import a August 89 Gtr32 in November! There getting quick these days! Well that aint so sacastic for you all.. 14 days and longest like a month! :) oh i cant whinge about that.. i can only whinge about not driving it now.. and paying the holding fees at the docks!! Enough from me.. but i guess if someone asks me if it was worth importing affter my first drive which should be next week i guess ill say hell yeah but now, i should of just brought one here!
Hey guys, i sent my import approval off about 2 weeks before the correct month and i got it back in record time. The thing to consider is that the time it takes to receive back your approval is mostly taken up by the application waiting to be processed. It only takes then a few minutes to process it. So i received my approval back in excellent time and was very happy. Since then, earlier this week i heard that my car was landing today in brisbane (KIWI carrier). I wasent even aware it had gotton on board a ship! So that was very exciting. The car will be trucked down to me in Melbourne to my door after it passes thru customs and quarantine. So it should be in my hands in about 2 weeks max! Very excited. I've never even driven a GTR lol. I have had a fair bit of experience driving high powered turbo cars but never a GTR. Im sure it wont let me down :D
what agent did you use GODZILLA32??
I wasent going to use a Customs agent as my friend has imported alot of cars himself, but in the end when the lady called i think from KIWI car carriers i decided to just let them handle it all and be done with it. You can call the people im using on 03 9614 8100. Ask for Nicki Groves.
Well, I put mine through on the 25th last month, and got it today - that's a 20 day turnaround which is exactly how long they said it would take.
I would be happy - however i have sweet F.A chance of getting it on a ship any time soon!
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
