I've got this strange problem with my indicator. It won't stop ticking after i use it or when it gets back to the centre. The lights switches off but the ticking noise won't go away or slowly slows down but won't completely stop. This happens both after signalling left and right, and after switching off the hazard light.
Anyone ever had this problem before or knows wats going on here? Please help.
oh its an r33 gts.
Thanx in advance.
https://www.sau.com.au/forums/topic/50296-indicator-problem/
Have had the same problem (intermittent) for 2 yrs now.
Can be very annoying when it happens and often seems to do it just to piss you off. Mine is occasionally accompanied by a wisp of smoke from the steering column, like a component or some PCB track is getting cooked. It surprises me that the indicators still work.
In short, I cannot really give you any clues but, I will watch this thread closely. And you are not alone.
El Bee
the alarms all good, but can u explain more about the relay and the flasher unit how i can get to these and test it etc...
Cheers
my guess is the switch itself , they play up just like the headlights .
take it out and have a look at the contacts .
El Bee
no sh*t i just had my first wisp of smoke coming from the exact same place this morning while playing around with both the indicators and the hazard light, scares the living daylite out of me lol.
Any other ideas people, and how much does the switch costs to replace?
thanx
OMG... this had been happening with me for a while now too. On Sat i took part of my dash out, found the unit that makes the ticking sound - soz i didnt take pictures, the camera was flat.
The unit looked to be in good order, and i thought i'd leave it disconnected to stop the sound.. heh.. but that makes the indicators not work At All! Not even the hazards.
I have had the soke from the steering column as well.. a ripped off the tiller housing but, couldnt see any wires that looked shorted, all wrapped up in black tape..
I suspect it might be with dodgy wiring of the turbo timer (i have an apexi pen type TT) or immobiliser unit... I too would like any recommendations on how to fix this issue... i really dont want to take it to an auto elec who has no idea about imports with turbo timers and stuff.
azron i know which unit you disconnected cause i did the same thing yesterday and the whole thing didn't work. Its the rectangular cube thing next to the cyclinder tube unit, it was 3 flat plug (not really good at explaining this) connection thing, it think is got a english tag label that says something like "MILES" and other stuff.
Just out of interest wat engine oil do u guys use, i've got the castrol magnatec 10W/40.
ta.
ok guys found out wat the problem is, its the indicator switch itself which is in the steering column (where the smoke came from), not the flasher relay cause thats under the dash ontop of your left foot.
Only problem is to find the replacement switch. Might try wreckers or somethin, or ni$$an if its not too expensive.
:D
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
