hi all
i think i am getting very ripped off on my 3" aluminium piping, and i was wanting to know from people in sydney where they get theirs from and for how much...
i got one 90 deg for $10, and this other place wants about $50 for the same thing... i have no idea where i got the $10 one from, but yeah, i remember it was $10...
so anyone in syd know where u can get cheap piping please post it here
thanks
My last one cost $380 including silicone hose and stainless steel clamps. I bought straight 63mm alloy off cuts from Capral and two 360 degree donuts from GCG. I cut the donuts to make 9 X 45 degree bends, 3 X 90 degree bends and 1 X 120 degree bend. I took the bits along to Mick (Mick's Metalcraft) and he welded it up for me.
Thanks Syd that sounds a bit better.
Mick's quoted me $1000 (i'm assuming off-the-street price) for doing my pipes. ha!
That's for Mick to design and make them from scratch, I only got him to do the welding because our fabricator was really busy making a new rear end for the RX7.
Next time I think I will use these instead of donuts, cost a bit more, but a better job I think....
ok, finished my piping :)
total cost
aluminium mandrel bend 3"
Pipes: 6*90 and 2*45 = $120
truck silicon hose: = $40
intercooler: = $400
clamps: = $60
i did all the work myself, and i think it looks pretty good...
i will take some photos of it later
total cost
intercooler: = $400
clamps: = $60
Please warpz0r, where did you buy each piece from?
the intercooler is a hybrid 600*70*30 i think
silicon hose is not the shiny one
but if it does the job, why do i need to pay extra for some shiny stuff that i dont care about as by engine bay isnt on display
i got the intercooler of EBAY
Silicon piping was from GCG
Clamps were from the plumbing section of Bunnings Hardware
and for the piping ask around and tell them that the pipes are too expensive and watch how much they drop... worked for me...
Warpz0r-
Where'd you get the piping from? I guess if you've already done it I can call them right now and say I know a guy got x y z and I want that they should do that right?
Does your cooler have hybrid stamped on the top?
I've heard they are really good and really crap from different people and don't know what to believe no more!
But yea please do tell where you got the pipes from - I will go there myself it sounds great !
Also when you say 6*90 that means you had to get 6 90 degree bends right?
Thanks for letting us know!
SK - What are those bends in the photo? They look Mandrel bends. I take it they are aluminium? Whats the deal they look alright.
Yeh luke they are good, hey? Much easier to use than the old donuts, I always stuff up at least one cut on them. They are mandrel bent and GCG sell them, plus they have a lipper onsite. So it's a breeze to plumb up you own pipework, just choose the bends, get them to whack the lips on them to stop the hose slipping off. Grab some straight silicone pipe and few clamps and play assemble the jigsaw when you get home. No welding necessary. :D
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
