hey all,
I am the proud owner of a fresh off teh boat cefiro with the RB20DET engine under the hood, it is my first time owning a turbo charged ride (past cars were silvia and supra both NA)... now this engine is almost completely stock apart from a 2.5" exhaust system.
What I want to know is what would be the most sensible upgrades to make on this engine to get a bit more punch.... I am not going to be able to fork out thousands in the near future so i am looking for the basic upgrades.
So air pod filter and ecu remap have been reccomended by one or two people, but I thought I would get a general concensus from the wider SAU population!
Let me know what you think.... If you have a resource online showing someones build up of an RB20 that would be tops too, i did google but didn't get too much success.
cheers all!
Luke
https://www.sau.com.au/forums/topic/50489-rb20det-modification-guidelines/
if it has an exhaust already then do the following if ur on a budget. The prices are what you should expect but will differ depending on where u go and who does the work for you:
-POD ($80 inc adaptor from Autobarn or Repco... fit it yourself and keep the stock box.)
-Bleed Valve ($60-$90 and run about 13psi on it)
-ECU Remap ($250-$300 depending where ur located allow money for dyno tuning if required. This will need to be remapped everytime you add something performance wise to the car.)
-Get some secondhand wider tyres for the rear like 235s or 215s ($100max sometimes more for 17s.)
That alone will get u into the mid 14second range (manual right?) and if ur a good driver into the lowish 14s. (pretty much the exact setup as was on my R32 except the 32 had damper adjustable suspension and a HD exedy clutch.)
-Finish off the exhaust if not done already with a dump and front pipe ($250 to $300)
-Hi Flow Cat ($230)
-Then get a nice HD clutch of some sort ($700+)
-Suspension setup (Can get some decent height or damper adjustable second hand jobs for less than a grand. S13 stuff should bolt straight up)
Then i would suggest upgrading the brakes on it... best to upgrade the whole system to something like the R32 GTST or R33 GTST or even the Z32 300ZX brakes like whats on my ceffy.
cheers for the replies, Inark, handy stuff mate. but yes it is a stockers auto... so I know I am losing a bit with the auto but its a daily driver in sh*tty city traffic so its been suiting it well.... the tweaked power is for the weekend fun....
ok well the pod is a sure thing, has anyone got a recommendation of the type to buy for easy fitting to the stock airbox unit?
so can someone tell me a bit about what a bleed valve does and how it is fitted?
the suspension is done, I had it dropped on sports ryder equipment a few weeks ago...
cheers
luke
autos are fine man... at least they are consistant unlike us :P
PODs... just get the cheapie one i suggested... you remove the std box... easy enough... 4 clips to get the top off... remove the filter panel and undo the 4 10mm bolts which go into the chasis. also disconnect it from the pipe leading to the turbo via the 8mm hose clamp.
Shouldnt be too hard to figure out how to attach the adaptor plate to the pod and then to the pipe where the box was connected to.
bleed valve is a little more difficult.. i will put up my guide on how to do it when i get home... it has plenty of large pictures to guide u through. A bleed valve is whats used to change the amount of boost you are running by bleeding air.
forgot to add u will also need a boost guage... there is no shortage of 2nd hand cheapies going around on most of the performance forums so dont be a stranger to the For Sale section...
i also have an installation guide on them too :P but its for an R32... BUT is done the exact same way and on the same engine so its all good :)
How much would an average comprehensive car insurance quote be for an R32 GTS-T?(most likely under my parents name, not quoted on me when im 18)....Im interested to know as i am looking into getting one when i get my P's as a first car. If anyone can find out for me that would be great.
Thanks in advance. :(
So yeah back on topic...
What I have is stock, with nice exaust. Prob GTR fuel pump, nice big pod, a bit of 3inch pipe going from the front bar to right in front of it. Bleedvalve at 12-13psi, depending on the weather (found it was faster on this than 14psi, I guess because of effeciency) Malpassie, and, a catch can, which I personnally found no gain from.
Anyway, this got me 195rwhp. All the mods I found a dencet boost from, I think I have spent $300... But I did get stuff cheap, and a fair bit was already on the car.
And with the auto... You can spool on the line better, and potentally get a better launch. You want faster times on the strip, let the tyres down!
sorry mate i couldnt find it... i'll have to make another one... i thought i copied it over from the last format... guess i was wrong... ive lost everything from my website
R32 GODZILLA, just go with just car man... Third party property + fire and theift damage... all sweet... that way if you wrap it round a telegraph pole... tough s%#t, you'll know better next time.. lol! but yeah, i'll stop goin off topic now :rofl:
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
