My GTR screams/whistles it's tits off when it comes on boost.
It's not the intake pipes, been checked.
It's not the Intercooler pipes, been checked.
It still boosts properly and is not down on power.
There is no extra exhaust noise.
There is no smoke, fuel or oil.
It still idles/drives perfectly except when you start to boost.
The noise is akin to a giant frog humping a Boeing 747.
Any ideas?
I was thinking a gasket around one of the turbos (hoping) or worst case, the turbo itself (which it won't be because I said so and I am not paying for new ones so they must be fine...:rofl: )
https://www.sau.com.au/forums/topic/50576-what-the-hell-is-this/
my car used to do this, i was still getting boost etc. turned out 2 of the studs that hold the turbo to the manifold had sheared off, and the manifold had warped slightly. not sure if this is the same noise though.
bov leaking a little? or else id suggest a manifold leak somewhere perhaps
Possibly but they on the other side of the car (although they do plumb back over to the other side) and the car isn't running rich so I can't see it being the pressure side of things.
Honestly would have to hear if it's more of a mechanical squeel or a high pressure air-ripping noise.
Maybe that's that noise I heard at Griffitth the other day...and I thought it was Mothra and Godzilla fighting
Starts as a whirrrrrrr then an almight scream. When it's low it sounds mechanical-ish but but once it's screaming it's air and lots of it.
So you've got both....that's just greedy :rofl:
Hmmm sounds like a listen and point mission, just get someone to give it a good rev while you stick your head under the bonnet...once you've got a fairly localised point of refererence you can start arranging a bank loan to cover the faulty part :D
Not the water pump is it....I had one that sounded like a banshee?
When it's free-revving it's fine, only under load and boosting it makes the noise.
Yeah sorry, without being there I can't really start to make any more conclusions on it...being under load, you'd assume it must be turbo related....maybe a hose has got a slight leak...like the squeeling a balloon makes when you pinch the end of it????
That's what the exhaust shop said but be buggered if I can find it!
it's the gasket or gaskets between turbo and manifold.
happens if the bolts holding the turbo to the manifold come loose or off in my case.
I had one go missing and that corner started leaking and burnt through the gasket.
when you start accelerating, it is a whirr, then as boost goes up, so does the scream and pitch.
I didn't lose any boost or power at first but eventaully I could feel that it was slugish.
if you don't replace the gasket/s, it will eventually leak at idle and you will get like a chuff chuff sound sort of like a lawn mower at idle.
nissan turbo to manifold gaskets are not that expensive.. if I remember, on my r32 gtst, it was $27 from GCG turbo's in sydney.
that pack contained the gaskets between turbo and manifold and some smaller ones for the oil and water lines.
Ok, your explaination is winning so far! Sorry Dan :wassup:
