My GTR screams/whistles it's tits off when it comes on boost.
It's not the intake pipes, been checked.
It's not the Intercooler pipes, been checked.
It still boosts properly and is not down on power.
There is no extra exhaust noise.
There is no smoke, fuel or oil.
It still idles/drives perfectly except when you start to boost.
The noise is akin to a giant frog humping a Boeing 747.
Any ideas?
I was thinking a gasket around one of the turbos (hoping) or worst case, the turbo itself (which it won't be because I said so and I am not paying for new ones so they must be fine...:rofl: )
https://www.sau.com.au/forums/topic/50576-what-the-hell-is-this/
my car used to do this, i was still getting boost etc. turned out 2 of the studs that hold the turbo to the manifold had sheared off, and the manifold had warped slightly. not sure if this is the same noise though.
bov leaking a little? or else id suggest a manifold leak somewhere perhaps
Possibly but they on the other side of the car (although they do plumb back over to the other side) and the car isn't running rich so I can't see it being the pressure side of things.
Honestly would have to hear if it's more of a mechanical squeel or a high pressure air-ripping noise.
Maybe that's that noise I heard at Griffitth the other day...and I thought it was Mothra and Godzilla fighting
Starts as a whirrrrrrr then an almight scream. When it's low it sounds mechanical-ish but but once it's screaming it's air and lots of it.
So you've got both....that's just greedy :rofl:
Hmmm sounds like a listen and point mission, just get someone to give it a good rev while you stick your head under the bonnet...once you've got a fairly localised point of refererence you can start arranging a bank loan to cover the faulty part :D
Not the water pump is it....I had one that sounded like a banshee?
When it's free-revving it's fine, only under load and boosting it makes the noise.
Yeah sorry, without being there I can't really start to make any more conclusions on it...being under load, you'd assume it must be turbo related....maybe a hose has got a slight leak...like the squeeling a balloon makes when you pinch the end of it????
That's what the exhaust shop said but be buggered if I can find it!
it's the gasket or gaskets between turbo and manifold.
happens if the bolts holding the turbo to the manifold come loose or off in my case.
I had one go missing and that corner started leaking and burnt through the gasket.
when you start accelerating, it is a whirr, then as boost goes up, so does the scream and pitch.
I didn't lose any boost or power at first but eventaully I could feel that it was slugish.
if you don't replace the gasket/s, it will eventually leak at idle and you will get like a chuff chuff sound sort of like a lawn mower at idle.
nissan turbo to manifold gaskets are not that expensive.. if I remember, on my r32 gtst, it was $27 from GCG turbo's in sydney.
that pack contained the gaskets between turbo and manifold and some smaller ones for the oil and water lines.
Ok, your explaination is winning so far! Sorry Dan :wassup:
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
