Hi Guys,
My RNN14 GTI-R is now up for sale. Here is all the details I can think of!
12/92 Nissan Pulsar GTI-R, black. 79000 k’s.
Interior:
Momo “Race” steering wheel
Razo gear knob and pedals
HKS type one multi timer/meter
Trust/Greddy 60mm boost gauge
Genuine Nissan floor mats
Factory power sunroof (very rare option)
Power windows
Retractable power mirrors
Air conditioning
Engine:
Chipped ecu
Exhaust – 3 inch front pipe, 3 inch high flow cat, 3 inch custom cat back system
Braided turbo oil feed line
Braided clutch line
Trust frount mount intercooler
Trust Type S blow off valve
Turbosmart bleed valve (set to 0.8 bar)
Urethane Engine mounts
M’s pod filter
Veilside oil filler cap
Cusco radiator cap
Twin core alloy Calsonic radiator
NGK high tension plug leads with NGK platinum spark plugs
Suspension and brakes:
Factory ABS brakes
Front strut brace
Rear strut brace
Race brakes front and rear brake pads, with slotted rotors
ADR compliant braided brake lines all around
Rebuilt rear callipers
Clutch pedal bracket
Tein type HA damper and height adjustable coil-over suspension
Whiteline Anti-lift kit
Whiteline adjustable rear sway bar
Whiteline link bushes and sway bar D bushes
Whiteline camber kit
Exterior:
Clear side and front indicators with silver fusion indicator bulbs
Alloy wheels with Toyo Trampio Tyres
New front bumper bar with tow hook cover
Stereo and alarm system:
Sony Head unit with 3, 4 volt pre outs
Clarion two channel amp, powering;
Boston Acoustics 6.5inch splits
Alpine 2 channel amp, powering;
Rockford Fosgate 10 inch sub
Flashpoint Level 4 alarm with 3 point immobiliser
History:
This car was imported in late 2002, by JappSport (formerly Fuji Motorsport) in Sydney. I was the first Australian owner, buying the car in December 2002. Since owning the car I have spent in excess of $10 000 to make the car what it is today, a neat, quick reliable street car :rant:. The stereo and alarm set-up alone was over $3000 and all suspension components were bought brand new with around $3000 spent there too.
Always serviced with Castrol formula R, 10W60 and genuine Nissan oil filters. Brake fluid used is Trust Super DOT 4.
All suspension components were professionally installed and set-up at Whiteline Suspension in Sydney.
All of the stereo and alarm components were installed by Lifestyle Car Audio.
The exhaust was custom made by Liverpool Exhausts
All other mechanical/service work was carried out at Rice Engineering in Sydney
The car has been dyno tuned to 156 all wheel kilowatts at only 0.85 bar boost at Premier Auto Centre.
Timing chain tensioner has been replaced and the timing chain inspected. CV boots have been replaced. Clutch master cylinder has been rebuilt. Starter motor has been replaced. Front wheel bearings have been replaced. All accessory belts have been replaced. Fuel filter has been changed. Engine has excellent compression across all cylinders.
The car has just under 4 months registration remaining.
This car has been owned and cared for by a true nissan enthusiast. The only reason I'm even selling it now is because I now own a GTR skyline. Registering, insuring and maintaining two cars is a bit silly for someone who doesn't even drive to work!
Asking $19 000.
I can't re-size the pics at work and one is 115kb the other is 142, if someone could do if for me so that I can upload them that would be great. Or whoever wants pics can request them here and I'll email them. Car is located in Sydney.
Please contact me (Richard) on 0405 186 433
Cheers. :cheers:
https://www.sau.com.au/forums/topic/50616-rnn14-gti-r/
Thanks mate.
Had plenty of calls and interest, but no-one has walked away with the keys yet.
Also, no swaps for other cars, I've already bought another car which is why I'm selling this one!
Richard
https://www.sau.com.au/forums/topic/50616-rnn14-gti-r/#findComment-1046852
link to pics says its been sold??
That's weird! Maybe they do that when you don't re-sucbscribe the ad? hmmm.
I'll give carpoint a ring.
Anyway, it's still for sale :D
Richard
https://www.sau.com.au/forums/topic/50616-rnn14-gti-r/#findComment-1062078
  • 4 weeks later...
bumped, still for sale. I'm now getting more keen to sell as the GTR is getting closer to arriving in Sydney. Anyone who's interested don't let the price put you off, it's a great car and I'll be happy to negotiate with an interested buyer.
Richard
https://www.sau.com.au/forums/topic/50616-rnn14-gti-r/#findComment-1087249
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
