Anyone have old surf board not using? I can borrow until I learn how to surf...
or
Can some one give me some advice on Purchasing one of Surf board for begginer?
I polly buy 2nd hand for my 1st one...
is there things I should look out for?
like
size
shape
soft or Hard?
etc..etc.
help is much appriciated...
cheers
Joe :)
https://www.sau.com.au/forums/topic/5076-surf-board/
PVA,
A good beginners board should a far bit taller than yourself (30cm at guess, maybe more maybe less), and depending on your weight, quite thick. Different people will say different things, but if you stick with those two points you should be right.
PS stay away from cash convertors for surf boards, most of the ones in store have beeen snapped one way or another! Careful!!
https://www.sau.com.au/forums/topic/5076-surf-board/#findComment-78559
Hi,
It Really depends on how heavy you are. But a rule of thumb is the more boyant it is the better to start off with. I would be looking for nothing under 6'5" high 18 3/4 wide and 2 1/2 thick. Something with rounded rails to stop you catching them when you get up. More then likely a square tail with a flat to vee bottom. But if you are learning from scratch a mini mal or an old boyant number would be ideal. Dont get a new looking light board as that will be to hard to learn on.
Depends how much you want to spend too.
Goodluck
Jason
https://www.sau.com.au/forums/topic/5076-surf-board/#findComment-78561
Guest GR33DyMANGO
yer i have about 10 boards. our house is like a surfboard cemetery.. hehe..... the boards i have are mainly trick boards (ie fish's around 6ft) but i do have one board that i may wanna sell that'd be good for learning on. its a 6'4" colin earle with thick rails and heavily glassed. if u wanna come and look at it my number is 040 127 6963. i live in floreat.
how high are u and how much do u weigh pva?
for a beginner u will need a board thats thicker and bigger than average so its more stable.
if u wanna practise its prolly best to start around summer when the waves are smaller. so nows a good time to buy a board. also if u want nice clean waves try going in the morning before the onshore winds come in.... or u can go really late (just when the sun is going down) and sometimes the wind seems to slow down a little and u only get a slight onshore breeze.
hope that can help.
https://www.sau.com.au/forums/topic/5076-surf-board/#findComment-78572
Guest GR33DyMANGO
adam 32 ive surfed contacios on saturday. was ok. howz the surf been? looks ok on the surfcam? nice and warm aswell :D
hey and pva.. u should prolly get a 6'3 to 6'5 and one thats a tad chunky to hold your weight. pretty much anyone thats learning should just get a chucky board (aka pig board).
.. just make sure u get a second hand board for your first season.. u'd be surprised how much u destroy a board when learning. haha.. when i started i caught a head and half sized wave straight into the front of city beach groyne.. leaving me with cuts with fibreglass inside my hands. every time i moved my hands i could feel the fibreglass breaking inside for about a month. anyway.. i ended up with 2 3ft boards after that:D
https://www.sau.com.au/forums/topic/5076-surf-board/#findComment-78931
    • I like they don't raise their hands into the air when they shift their sequential boxes, seems to be a thing here in Australia lol...
    • I'm not normally one for posting random videos, but I thought we'd all appreciate the honesty about how broken our cars tend to be lol. Genuine skyline life here.
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
