Baka Gaijin needs help with kanji tattoo....
Bl4cK32: that IS one kanji - thus can only be written that way
As far as I know, this is the more common kanji -
But both have the exact same reading 'ryuu' (dragon)
Just guessing (I'd have to ask), but perhaps the one you posted is a chinese character that was directly copied (and in use) by the japanese (I personally think the one you posted is more elegant)
the pics you have been posting are modern designs - taking the traditional and given it a 'tribal' makeover - they are relatively common though (and easy for any decent tattoist to do - no shading required, just outline and fill-in)
chinese vs japanese? haha, not my area of expertise - I'd have to ask him. The japanese have a story (maybe it comes from the chinese, I'm not sure) - something along the lines of a carp who swam back up a river and, to climb a waterfall, was changed into a dragon - which is one of the reasons that carp are often used - and often the carp and the dragon are merged (transformation pose)
myself, being a keen fisherman in australia, I could never get a dirty old carp tattooed on me!! :D but I've been trying to think of a way to incorporate a dragon into the side of my oni tattoo (though, to be culturally accurate, it should be a tiger, not a dragon)
okay, re: kanji - apparently the one I posted is a simplified form - somewhere down the line they decided it was easier to make a 10 stroke kanji (as opposed to continually writing a 17 stroke one). This is quite common - having an original ('difficult') kanji, and a later, modified version ('easy')
Cool...so the both mean the same then. I like the tribal tats because of the lack of colours. Relies more on the drawing itself rather than the shading to make the pic....that and the $$ ;)
I think i'll go for the one i posted...as you said more elegant to look at :( Now just gotta arange it some how...
  • 2 months later...
Hey,
Sorry to dredge up an old thread for my question, but I thought it would be more prudent to tack it on here than to start a new thread.
Can anyone offer me an explaination of the below Kanji and what it means, if it even means anything?
I have been told it the characters are pronounced "Rai" + "an". Obviously this is why I'm interested... although I know getting your own name tattooed on yourself is a bit cheesy.
Cheers!
from what remember when I was designing a dragon tat for a freind and talking to the local chinese tattoo artist, if the dragon had whiskers or if it had a forked tongue, it was supposed to be a chinese dragon or something like that... I dunno can someone confirm?
So my name means Dark Thunder in Kanji?
Sweet.
Or is it Thunder Dark which is meaningless?
Also what about "Rai" + "un"?
Well straight direct translation is Thunder Dark (sounds bit like odering a Coffee Black) :) . But u can call yourself Dark Thunder if u want.. :ufo: ..
When u only put these 2 words together Thunder Dark they dont mean much.
"Rai" + "Un" <== are u referring to Chinese pronounciation? They sound similar. In Chinese, the correct pronounciation "Lei" "An" , I think...which doesnt sound close enough to Ryan...i think "Lai" "En" would probably sound closer to Ryan.
ooooh wow tattoos!
i wanna get a tattoo but cant commit for the fear of regretting it later in life...
but if i was to get one, i wouldnt settle for a little thing on my arm or shoulder. i'd go full out and get a huge fcuk-off dragon tattoo that would span the length of my body.
i saw it in a korean movie called "jopog manura" or in english "my wife is a gangster"
in it, there is a scene where the chick (who is a gangster) shows the tat and its a black dragon with iths head starting on the right shoulder, its body running down her back, ass and thighs, and the tail ends just below the back of the legs. i must say its the BEST tattoo i have ever seen. i'll try to get a screen shot here later and when you guys see it, im sure you will agree.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
