The drivers side power window has been slowly dieing and is now completely dead and wound all the way down too, so I can't really drive anywhere and leave it :D
I've pulled out the mechanism that all the buttons are on and checked the wires which visibly look ok, all other buttons on it are functioning fine.
Any ideas what parts I'm looking for, is the mechanism with all the buttons on it the actual motor or is that a seperate part?
TAI!
https://www.sau.com.au/forums/topic/50963-broken-drivers-power-window/
Had the window been going down on a strange angle b4 that, i had the nylon roller break on me in the runners. Made up a new one b4 it put too much stress on winder motor. Also their may have been a loud bang if runner came out of balljoint. If not then i'd say ur motor is faulty. Cheers
most likely the switch....same problem happened to me. Because the switch was faulty (the drivers side has the 2mode switch...hold down/up to operate or just one touch for automatic) the switch would remain on and so burnt out the motor...so new switch and motor - $150 each. Then my switch needed to be rebuilt so add another $150. Note that there is a difference in switches...my '93 R33 series 1 switch was different to normal...something about a change is design between series....
Easiest way to find out would be to get a friends driver side button thingo, pull it out (its only 1 screw from inside the handle)unplug it and then plug it into your door. If its still no go then your window motor is fkt. My mate had a window motor replaced on his r33 but the guy didnt' put in a skyline one because he couldn't find one, so he popped in another window motor and the window used to go up like 3 times faster than a normal skyline window motor hehe.
same thing happened to me tonite. I used to hit da door quite a few times and it used to come up. But now i've tried everything and it won't go up. i'm hoping it is only the switch because it neva has a problem going down. but $150 for a new switch??? can i get dem ne cheaper??? or any way just to trick it back up and never use the window again?
my power window hasnt been workin for weeks now and its bloody anoying when u go drive thru or need to talk to someone. wat u do is flick the switch up a couple times till u hear the motor turn and then help it out by pulling up on the window with ur hand. or disconect the motor from the switch and run alternate power to it. mine didnt seem to work when i did that so i assume my motors stuffed not my switch.
JAPCAP -- any chance u could find out what motor that was?? im sure theres other motors out there that would fit. maybe 200sx motors??
  • 5 years later...
It always is the power window regulator and its a common problem (& no, it is not the switch). I replaced mine 3 years ago with a second hand one I found for 75$. Did it myself its not too hard. The damn thing just happened yet again n i got a quote for one and its going to be 195$ for the part now. Thinking of trying to repair the old one this time, its the little bit of carbon pad that gets worn off, the mechanism is completely find asides that. Its a very long shot, will let you know if I have any success with it.
had the same problem with my swich, found that the lever under the button to acivate the upward swich was broken, would go down fine but wouldnt go up. ended up buying another p/w swich for $50 havent had problems since
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
