HKS T04E kit ( cast iron manifold, external gate and T04e turbo ) $1,595
HKS T04E kit ( cast iron manifold, external gate and T04e turbo ) $1,695
600cc R32 Injs and std GTR fuel rail $650
Trust Boost Gauge - White Face ( mech ) $195
HKS Boost Gauge ( 2 bar ) mech & holder $220
HKS Boost Gauge ( 2 bar ) mech & holder 52mm $220
Apexi Boost Gauge ( 2 bar ) mech & holder $220
Apexi 260 / 8.9mm Cams $660
RB26 Cams, lifters, shims and valve springs (270/10.25mm) $1,550
STD RB26 cams $275
HKS Cams - Step 2 ( 264/9.6mm) $770
Greddy - RB20/25 T3 Flange Ex Mani $715
Greddy - RB20/25 TD Ex mani $770
HKS Cast Iron mani ( T4 flange and ex gate provision ) $495
Greddy - RB20/25/26 Cam Gears - Brand New $470
HKS Cam Gears ( used - old style ) $350
R32 GTR Injectors $295
R31 Adjustable Front Coilovers and hubs $420
R31 Projector headlights $300
R31 Adjustable Cusco Strut tops $240
R31 Adjustable Gabs Strut inserts - Brand New $395
R31 Tomei 240kmph Speedo $495
R33 RB25DET Coil Packs $275
R32 RB26 Coil Packs $330
Q45 AFM & Connector $295
Z32 AFM & Connector $310
HKS R32 GTR Pod Filters $210
RB Remote Oil Filter $175
R32 GTR full wiring Harness $330
RB25DET HEAD $400
Nismo 555cc RB25DET Injectors $750
RB26 Head - Complete - Cams, cam wheels, valves, springs , lifters etc, CAS, Coil Packs, Cam Covers, Timing Belt Cover, Ignitor box, Plenum and fuel rail, exhaust manifolds $1,590
RB26 Head - Cams, cam wheels, valves, springs , lifters , Cam Covers, Timing Belt Cover, Plenum $1,450
RB26 Head - Cams, cam wheels, valves, springs , lifters , Cam Covers, Timing Belt Cover, $1,100
RB26 Head - Cams, valves, springs , lifters , Timing Belt Cover, $880
RB26 Head - Cams, valves, springs , lifters $880
EMAIL: [email protected]
https://www.sau.com.au/forums/topic/51095-parts-galore/
Pics on the way.
No real difference apart from one comes with a braided oil line and the manifold and wastegate have been bead blasted.
Cheers
Can i get some pics of the hks turbo kits.
[email protected].
Wat is the difference between the two kits you have available.
Thanx
https://www.sau.com.au/forums/topic/51095-parts-galore/#findComment-1017573
Hi Spoolup, please let me know of you have a single HKS manifold for sale by itself, and or a set of top mount twin manifolds.
Mostly I'm looking for the HKS cast single, but I'm open to others.
thanks
J.
[email protected]
https://www.sau.com.au/forums/topic/51095-parts-galore/#findComment-1017771
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
