  • Replies 90
My Budget RB20DET-
Imported with HKS Super Dragger exhaust and K&N Big Mother air pod
Added TurboSmart boost controller - $250, dynoed @ 150rwkw
Added Dump Pipe - $300
Added Cold Air Induction - Free
Added RB25 Turbo - $350
Added Front-Mount - $500 (inc pipes, see http://www.skylinesaustralia.com/forums/sh...ead.php?t=47918)
Added additional Cold Air Induction - $50
Next I want to remap the ECU and then it's time to Dyno it again. Hopeing to be around 200rwkw for around $1K. Then that's it with RB20DET, move on before blowing the budget.
I don't think you can achieve a real 200rwkw with the small stock injectors, from the dyno i have experience with, the stock injectors will max out 180rwkw and by then the mixtures will be fairly lean at that.
My Rb20 with RB25 turbo, pod and 3" turbo back exhaust did only 130 rwkw with stock boost and everything else and 11.3 A/F ratio.
My RB20 did 150rwkw with 3" cat back exhaust, pod and turbo smart boost controller on the UAS dyno. What Dyno where you running it on? I've now got a FMIC, 3" dump pipe, CAI and an RB25 turbo, hasnt been dyno'ed with the latest mods yet however.
my 2c...which aint much :)
buy a rb30 bottom end from wreckers (mine cost $100 ;))
buy an rb25de head (mine cost $750)
do a std bottom end rebuild of the rb30 using same pistons, just hone, new rings and bearings ($850?)
bolt on head to block, drill tap tensioner, $30 timing belt, 2x rb30 tensioners ($80 ea)
how much so far?...using rb20 sump, manifolds, turbo (i am to start :)) water pump, rb20 oil pump....no costs here.
redrill engine mounts to lower engine, plug in rb20 sensors, mod front pipe.
done...turn key and watch the rb30 rumble for under 2k.
But as they say...the spending never stops once it starts....i wish i had kept to the plan above and watch people grin :)
Seriously though i had the same drama as you. Rb20 blew, and went the rb31. Never look back now :)
The rebuild costs your mentioning, is that doing it yourself? Would there be the need for any boring or machining?
Na stock injectors are good for 200-220rwkw. my 32 makes 190rwkw with stock injectors, pump, reg etc no worries.
I didn't think you could put the rb20 head onto the rb30 bottom end? Is what your saying just a miss type? Or can it really be done?
Using my Rb20 head would be a lot more easy, then looking for an rb25 head if I went that way with a motor build up.
Shoot about 10 years ago using an RB20 cylinder head on RB30's was common. It is a prick of a job, welding, redrilling machining etc. But the result was better than a SOHC cylinder head. Wouldn't even think of doing it now with RB25 cylinder head's being so common and RB26 top ends being almost affordable. :P
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
