Hi all,
I just bought myself an r32 gtst, and ive got a few questions:
Where is the ambient temperature sensor for the climate control - cos the one in my car keeps reading 45.9 degrees no matter how cold it is :thumbsup:, and how would i go about finding a replacement part if its stuffed.
What does it mean if the HICAS light comes on - It has come on only twice since ive had it, and only when i've been drving for extended periods over 100kmph eg going down the freeway. Does it mean that the rear-wheel steering is on, or buggered??
Thanks in advance
https://www.sau.com.au/forums/topic/51219-new-car-a-few-questions/
top of the dash in front of the passenger is the ambient temp sensor. Try a second hand one from the forums, or a wreckers. There is a dignostic mode for the climate control as well...
HICAS light can mean a number of things...powersteering fluid, or brake fluid could be low. Need a wheel alignment.
o a diagnostic check on the HICAS as well....should narrow down the problems at least to give you somewhere to start.
hicas light shows when the hicas isnt working
ive got the same problem but mines on all the time
apparently its really common with the r32s
and for the climate control sensor u can pick one up from "Wally" at Zimports 8244 7911
179 South Terrace, Wingfield
he has heaps of standard parts at very good prices too!
I'd get rid of the HICAS, replacement kits are available for around $100, and then take the bulb out of the dash
Mine used to play up all the time, so it has been replaced with a solid bar, and it works really well - feels much more stable and predictable :rofl:
My ambient temp sensor is at the front of the car.
It used to be located where the FMIC now is. I simply moved it to the side a little.
The sensor on the top of the dash on the passenger side is a sunload sensor.
The sensor on the right hand side of the center console right next to the gearshifter boot is the in car temp sensor I believe.
They all go hand in hand working out the temps, where to blow cool and warm air etc :D
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
