Hey guys well finally after years of drooling over them, i bought my first skyline a '93 R33, probably wasnt the easiest purchase to manage living in the country and buying a car privately in sydney but it was worth it in the end.
Currently just has a 3 inch cat back exhaust, a boost controller and the rims, but more mods are planned soon when the cash is available. So what do you all think?? Also any advice on the next mods?
But i have to say there are some advantages of living in the country, full comp insurance with JCI was $2620 for a 19 yr old with no accidents but i guess the 30% nci helped. Here are some pics.
https://www.sau.com.au/forums/topic/51391-my-first-skyline/
There are about 5 R33's in town an a couple of 32's and a 34 which i have only seen twice. But mostly bogan cars around this area, they are alright its the mllion lancers and excels with their stickers, neons and big exhaust which are the biggest pain in the arse, if i didnt care about my licence i would show them what a real car can do.
Yeah i bought it with a bleed valve i meant not an ebc, it also has a Brass button clutch which has made it interesting to lget used to seeing my last ride was a 1976 Chrysler Lancer.
Also anyone know what the widest tyres on the rear you can have at the moment mine are 265/35/18 is that alright, the fronts are 235/40/18, wheels are 18X9 all round. Thanks guys and i will keep safe dont worry!!
https://www.sau.com.au/forums/topic/51391-my-first-skyline/#findComment-1017999
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
