FJ all the way he said with a shit load of work! he was saying he was having trouble with wheel spin running 235's, very nice car outside and in. he said he's from Gympie drove down for the meet, there was also a 4door DR there too i think it was the one from HPI on the coast didn't see it? took me r31 as a part of the r31skyline club here in QLD...
https://www.sau.com.au/forums/topic/51407-dr30-at-j14/#findComment-1018139
yeah two runs for the castrol gtr into the 10's, there were also a few other gtrs into the 12's, one head to head run by a blue (very stock looking) r34 gtr and a silver slightly modded looking r34 gtr both ran high 12's my mate may have the run on film i'll ask later today. a lot of r33 gts-ts running also 12's as well. might go back for the finals today if i'm alive..
https://www.sau.com.au/forums/topic/51407-dr30-at-j14/#findComment-1018143
u should definately go today because an episode of 'Fat Pizza' is being filmed there. Habib and Pauly are judging the bikini babe contest. Should be really funny. You should get in the crowd, right up the front so u can get on the tV :D Maybe you should leave now so you can get in the front row!!!
https://www.sau.com.au/forums/topic/51407-dr30-at-j14/#findComment-1018144
Dear oh dear,why do people have to bullsH!t about there cars? UNLESS this guy has done some major work on it since purchasing it--and it doesn't look like it from the pics--then it's near stock.....It's the late model high comp engine,with the old T3 on it.Runs 14psi (well,used to) and has an intercooler that's surposedly off a light truck (torque-liner or such) exhaust and air filter.....that's it.
https://www.sau.com.au/forums/topic/51407-dr30-at-j14/#findComment-1018586
went to the fast fours jamboree today saw some mad cars and even better times but was surprized to see a 2door DR30 there,l spoke to the bloke saw him do a pass 14.4 i think at 9? miles an hour, heres some pics.
Even with wheelspin/traction issues, 90 odd mile an hour terminal speed isnt that great for a dr with a "shit load of work" done to it..
What did the other 4 door dr do time wise??
https://www.sau.com.au/forums/topic/51407-dr30-at-j14/#findComment-1019109
  • 2 months later...
hi, was just told about this thread so sorry of its lateness. I now own this car which i brought off a bloke call darren. the only changes made to the car since buying it have been fixing the one of the bilstrin shocks twice, a new alternator, a new head after i bent 2 valves(this was fixed just before jambo). Traction is a problem as it either bogs down or just go's into wheelspin. My 4 runs at the jambo were 13.9 @ 101.81, 14.1 @ 101.17, 14.2 @ 100.74, 14.3 @101.6. after xmas i plan to replace the gearbox with a RB20 box, fit better tyre then the one from the jambo and hopefully it will show its true colours.
robert
https://www.sau.com.au/forums/topic/51407-dr30-at-j14/#findComment-1110921
I thought the FJ box was stronger than the RB20 box, but not the RB25 one?
Nope RB20 is stronger then FJ, but the RB25 kills the pair of them with strength, think of the RB25 box as the same as a GTR box without the transfer case on it :D
https://www.sau.com.au/forums/topic/51407-dr30-at-j14/#findComment-1111568
this is what i was told on FJ20.com
"The only thing that I would add is that my T box was replaced by a RB20DET box. The RB shifter is a lot better (it self centers on 3-4), the box length is the same and it has that larger front counter shaft bearing which is important. There are other advantages such as heavier selectors too.
It was a straight bolt up after doing some top bolt holes relocation to the front casing on a mill."
is the RB25 box the same lenght as the RB20?
robert
https://www.sau.com.au/forums/topic/51407-dr30-at-j14/#findComment-1112727
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
    • The stock manifold is "mostly" divided. The divider actually has a notch cut out of it where it would meet the divider on a twin scroll housing. I have no idea why. But whatever the reason, it would cause some cross talk when used with a twin scroll housing. People do put twin scroll housings onto that manifold. But I'm of the opinion that proper twin scroll internal gating is...not really possible at this scale. You'd be throwing good effort (ie $$) after bad, when you really should be doing something else. Notwithstanding that.... I am not sure what the idea that you are floating has to do with the difference in comp cover position caused by the highflow using a shorter length core than the stock Hitachi one. Can you clarify what you meant?
    • Majority of regulars are > 30. We all act at least 50. Definitely not friendly as we're all grumpy. 😛
