between a ceffy and an S13???
does anyone know for certain or have a list of stuff that is??
a better description that "suspension" too :D ie. tie rods, castor arms, coilovers will fit etc
cheers
https://www.sau.com.au/forums/topic/51486-list-of-interchangable-parts/
Stock S13 susp. will drop the cef 1.5 inches (or something like that) due to it's weight and the like...
coilovers fit, the ONLY thing you must do with S13 suspension is the upper bushings are offset on an angle, while the A31 bushings are inline
for example, if you had the two suspensions lined up with the bottom "o" rings facing the same direction, (O = bushing and X = bolts to the car) they would looke like this
X X
O(a31) and O (S13
X X
this is fixed by loosening the central bolt and swiveling the bushing, then slotting it into the A31 then redoing it up (if that makes any sense, i hope the dogpoo diagram i made makes sense and doesn't come out muddled up on the site...)
OK so it muddled up and now makes NO SENSE whatsoever, THAT'S IT I'M NEVER POSTING EVER AGAIN!!!!
i used S13 front seatbelts in my cef as mine were stuffed... so i guess they fit.
* Coilovers are the same
* front brace are the same, but rear is same as R32 is the strut top holes are different rotation (as per Mr Eps screwed up diagram), or S13 ones can be redrilled to fit
* front brakes and stub axles are the same as SR20DET S13 (ie woeful)
* front lower control arms are the same
* front castor arms are the same
* all rear arms are interchangable.
* engines are interchangable (well, SR into my Ceffy seems to fit anyway :cheers:
I have heard that the swaybars are same as either S13 or R32.. I'll have to try my spare S13 ones to check
I have a cef and 2 x s13's at home, so finding things out like this is pretty easy for me.
Seats are the same rail design as R32 and R33.
JK
You sure??? Cause I have some mighty big holes around my rails, and I have R33 seats in there. And the r33 rails dont look as if they are in the stock holes.
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
