I experience something similar to you too, although I havn't removed the fuse.
I noticed it ever since I got a momo steering wheel fitted, and also the light comes on when traveling over 70k's for about 20 mins or longer.
Bloody HICAS!!!
It must be better around bends at higher speeds otherwise it wouldn't have been fitted.
Take it easy
Mark
Hmm.. I'm finding that in my R32 as well.
I recently bought my car about a month or two ago.. and it has an aftermarket steering wheel (not a momo, but similar shape and size).
However the hicas warning light only comes on sometimes when going over 70kpm..
and strangely I had a wheel aligment done on Friday and car still pulls to the left at low speeds.. not sure if hicas is prematurely just being weird!
HICAS is not your friend, every Skyline I own or have ever owned has had all evidence of HICAS removed by me. It's the first bit of suspension work I do. Thank heavens the Stagea doesn't have HICAS, so I don't have to remove it.
Have a read on HICAS in the suspension section, if you want to know more. :D
Hmmm what’s the go with removing the HICAS fuse then... Is that an easy solution or worth doing? I cant say i've felt HICAS, seeing i have a locked diff the back likes getting out sideways anyway....
I dont have a problem with my car so i wont change anything to do with HICAS i spose. I just wanted know when it kicks in, and how does it feel, good, bad?, Im thinking Sydneykid is gona say bad.
Hey Sydneykid... wana make your Sig pic any larger?
As mentioned it that forum.. I've already ordered an electronic HICAS controller from GRID in Japan. I just hope it sorts out the problems as effectively as physically locking it up.
HICAS controller? You mean HICAS canceller? or are we talking about the GRID ETS ATTESA controller now?
Richard
Hi geno8r, following are some of my previous posts on HICAS;
I believe that removing the HICAS is a good move for a couple of reasons...........
Firstly I like to be in control of the rear end via the throttle. The HICAS computer is slow and dumb, ie; it doesn't act very quickly and only has limited inputs. So it does things too late and sometimes they are the wrong things. It tries to help the rear traction by steering the wheels and this works OK, but only for as long as the car is within the traction limits of the tyre.
Secondly, rear tyres don't like to be twisted around when they are already under a lot of side load and scrambling for traction. The HICAS movement of the tyre is enough to break the contact patch on the road and the car slides. Sometimes a little, sometimes a lot. Then the HICAS tries to fix that by changing the steering angle and the whole thing starts all over again.
So, to answer your question, sometimes the HICAS adds to the oversteer and sometimes it doesn't. That's the killer, with the throttle and suspension setup, I have consistency. This gives the driver more confidence and consequently you can drive the car closer to the limits (ie; faster).
we remove all of the HICAS stuff of our R32 road/race cars. We replace the rear rack with an billet alloy block, shaped and threaded to suit. This locks the rear wheels and stops them from steering. Just pulling the fuse will still allow some movement under load.
We remove all of the pipes, hose fittings, mounting blocks and the rear (1) and front (2) solenoids. We then take the hose that usually goes from the power steering pump to the front solenoids and re-route it so the fluid goes straight through the oil cooler pipe.
Removing all this saves almost 30 kgs (including the excess fluid) and the car handles much more predicably on the circuit and on the road. None of the GTR's circuit race cars I have seen anywhere in the world (including the Gibson ones here in Australia) ran the HICAS.
Simple HICAS bypass kits are available from people like Jun, Apexi, Tomei etc. They have a couple of washers that stop the rack from moving and an electronic box that tricks the HICAS computer into thinking the rack is still working and so the dashboard warning light doesn't come on.
There are other kits around that have a replacement for the rack and a small bypass hose that goes between the two standard hoses at the rear rack. This makes the HICAS computer think the rack is still working and so the dashboard warning light doesn't come on. Stillen make kits like this for Z32's.
There are relatively cheap solid rear rack replacements available (eg; Japanese Motorsport) but the HICAS warning light comes on when you remove all of the other stuff. Some people remove the bulb to fix this problem.
My suggestion to people when they ask about HICAS is to remove it totally cause it saves weight and the car handles better. If they don't want to go to all the trouble and expense that involves, then I tell them to use a Tomei kit. Takes under an hour to fit by an amateur with limited tools. Whatever way you do it, the car will need a wheel alignment when finished.
This is the Stillen rear rack replacement in billet alloy, similar to what we use on the race R32's
http://www.stillen.com/product_images/308550.jpg
Hope that helps.
Cheers for that info Sydneykid, How old are you m8? You certainly sound to have a lot of experience with cars...
Well, lets put it this way, the "kid" in Sydneykid is for fun :wassup: I mostly worked on circuit race cars and there you learn heaps of stuff real fast. I also write articles for magazines, mostly on suspension and do a bit of driver training to go with the race team data logging and interpretation. It's all good fun. :D
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
