  • Replies 309
Predator.
Wether you can get it done at an exhaust shop is up to you.
It's quite a complex bit of gear, as it includes the BOV and PVC return attachements.
Your call, but I'll have definent prices in about a week or so.
i'm very interested at around $100, also interested in timeframe as a move interstate might be hapening around Jan so i would want it on by then..
car = R32 GTSt
would want black silicone too so that i could paint the pipe black to go with my sleeper theme :(
cheers,
Warren.
Darrin.
Due to the infinite amount of different combination of parts and things I would prefer to only make them up to standard specifications.
This way it saves the project going into a tailspin and trying to make up 10 different pipes.
However, if you were to tell me that you wanted an extra 50mm on the end that goes to the AFM, I'm sure we could work something out.
SydneyKid.
No problems. If they are the same, then this group buy is open to those with Stageas then.
Also, as thanks for the outstanding level of advice and helpful comment from SydneyKid, he will recieve one which will be sponsered by all of us (is Free of Charge).
BASS OUT
Now thats what I'm talking about!!!
Great idea Junky...
yea i'm keen .. sounds farking good to me too...
R31 Coupe - RB20DET ........ should be the same as anyone elses .. i should think ..
For 100bucks shit ..we'll be laughin
Matt
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
