  • Replies 309
I'm considering that.
Makaveli.
Check the first thread for a full description.
Price should be somewhere between $100 to $150 depending on many things.
Are you in?
ICE. You are already in.
Nobody is late yet. I haven't even made the prototype for the R34 yet.
Look's like I will have different ones for R32 and R33!
I don't think I will be ready for payments for another month yet, so don't worry too much.
Okay, Update time.
Yesterday I went and bought some P.V.C pipe, 3 inch in diameter, which I am going to heat up and bend to make up a dummy pipe to take to the fabricators.
This will give them a better idea as to a couple of things.
It was also suggested to me yesterday to use 3 inch pipe the whole way and simply reduce the diamter with a reducing hose from 3" to 2.5".
This is sounding like a good idea because if somebody goes a changes a turbo with a bigger mouth, all they would have to do to the inlet duct is change the reducing hose.
If anybody feels this will be a problem, please let me know. I think that if the reducing bush has a resonable angle on the step that it will be fine.
Any problems, please post, if you don't have a problem with it, please don't post as this thread is going to be obscenely long soon!
BASS OUT
Thank AnFz, you have put the quantity at 50!!
I need a couple of things please.
Could somebody with a standard AirBox from an R32 and R33 please photograph and post a pic of the airbox. View needed is from the AFM outlet side.
I know that the R34 air goes into the top of the box, through the filter and into the AFM, and I think that the R33 and R32 air goes in the bottom, through the filter and out the top.
Please post a pic or two to help me out.
BASS OUT
(P.S I had a look at the Apexi POWER INTAKE kit, and it costs from $500 up, plus freight! The Power Intake is basically what I'm making now!)
Hey Guys.
Just took my jig and the pipe that Jager lent to me (THANKS JAGER) over to my fabricators and they are going to make up a prototype for me. May not get it before the cruise but I'm hoping I will.
I've got an R33 and R32 rubber pipe here and from what I can see, the section immediately before the turbo is the same, with the BOV and PCV return bits in the same spot, but the actual location of the AFM is different.
Looks like each one will be a different pipe. Shithouse.
Oh well, just makes it more fun.
I've decided that the hoses will come from Shift Performance and these will be in Blue.
I know that conflicts with some stealth concepts but they seem to have the right stuff at the right price.
They also have red versions of the hoses but they are more expensive.
More about this towards the end of the project.
I don't yet have firm prices as I'm waiting for the prototype to be made up to recieve a price from my fabricators.
I have prices on all other bits though.
You will use your existing hose clamps from the AFM and Turbo, and I can supply extra clamps for the silicone hose (one for AFM and one for Turbo).
As we are going to have to cut the BOV and PCV return pipes back about 20 mm each, I will also supply the silicone (or rubber, depending on what sizes are available) hoses and clamps for these.
As you can see, this is a fairly in depth project.
Anyway, I'm going to be anxious until I get my prototype either just before or just after the cruise in Melbourne, so hopefully I will be able to show people my wares soon.
BASS OUT
Bob,
I'm gonna put you down on the list anyway, because I know the prices are going to be irresistable and the quality will be second to none.
You can always pull out later.
I seem to be Whoring my own thread.
Okay, I need a little help and the use of an R32 and R33 Skyline for a Saturday morning.
I need to do what I did to my R34 and make up a jig for my fabricators.
This will involve you coming to my work on a Saturday morning for about 3 to 4 hours and helping me remove bit of your engine bay in order to remove the rubber duct and weld some rings together to make the jig.
You would preferably be a bit hands on so we can get it pulled apart before 10am as that's when my fabricators go home, and so we can go home and wax our cars for the cruise.
This will happen on Saturday the 15th (Day before the cruise)
That's an R32 and R33 with STANDARD AIRBOXES fitted, or at least bring your standard airbox for the day.
Thanks, please let me know.
BASS OUT
Guest
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
