I have been shown ARP SR rod bolts on a GTS-t rod (you don't need the crank) just put the rod bolt thru at the big end and from what I saw, the nut only screws on about three turns of thread - leaving the nut half on and half off. Didn't look very safe to me.
* Caveat to this is what I was being shown was exactly what I had been told the bits were.
Yeah - what we need is for someone to take pics - I also wanna see the difference between a GTR Rod and a GTS-t Rod (standard).
And also the reason why GTR Forged Rod (aftermarked eg Eagle, etc) won't work on a GTS-t - ??
:confused:
Nup they work fine, we have just done 2 motors one with Forged Pistons and Forged crower rods. Using RB26 forged crower rods on a RB25.
Also I will take photos of my setup with, Rb25, using Rb26 Rods and Sr20 ARP Rod bolts. to confirm they work. When we checked the rod bolts the SR's were actually longer then the standard RB25 Rod bolts.
Also the photo attached is of the current Rb25 We built, with the forged rb26 crower rods and Arias Pistons.
I will upload another one before we put the sump on.
Hmm - that engine bay looks familiar :)
can BBQ or SST answer a few questions........u seem to have a bit of experience in this particular discussion....
i think the forum has agreed that rb30 rods are capable of pushing 400rwkw....ive seen many 3L punch out ~350rwkw on standard rods and are thrashed day in day out...
the weekest link being rod bolts...if u address this, shot peen them....wouldnt it make the rod pretty reliable??
a rb30 rod is physically thinner than a rb25 if i can recall......wouldnt this then make the rb25 rod physicallly stronger???
i just dont hear of rods shooting through blocks that often......
i also agree with peoples thoughts of revs killing rods....8000rpm i figure would be within the grasp of a shotpeened and rodbolted rb25 standard rod.....if i make 180kw at this figure the rod spins with the same rpm as when i make 300+kw....is this change required?
what i dont get is when u upgrade the pistons and rods to forged items.....y leave the crank STANDARD???
obviously u will think twice about reving ur motor to 10,000rpm???? or does it mean u can rev to 9,000rpm???
is it worth the ~$1500 upgrade ?
(obviously it is.... if ur pockets are deep enough, but what if they arent?...which i think that is what this thread is about)
y dont people address the crank too???......everything is rotating and pumping on one another isnt it??? well thats what i think...feel free to comment :D
Nissan cranks are very tough,ND4SPD turns to 10000+rpm and has never given any crank problems and an RB25 crank is a little shorter in stroke but the same build quality as a 26 crank so dont worry about hurting the crank if your build is done right.
As i said earler i have never seen any RB rod fail other than its bolts just a set of GTR rods are cheap peace of mind.
Brand new from japan
Tomei Crankshaft is $5,697.50 + $500 shipping and maby another $400 on import tax and duty.
forged pistons $1500
Forged con-rods $2400
Thats already $10,497 then if your doing the usual upgrades with bigger turbo, injectors, fuel pump etc:
Turbo $2000
Injectors $1000
Fuel pump $450
Z32 AFM: $460 - brand new
GReddy plenum: $1400
Apexi PFC: $1100
boost solonide for pfc: $350
etc... thats total of $17,257
Don't forget your machineing bill from the engine reconditioner :( - $2000 +
As steve stated the nissan cranks are very strong,
With forged internals you can rev you engine as much as you like but your (rb25det) head wont handel it eg: Cam shafts, valves, valve springs etc
Hope that helps,
:D
Originally this thread was started about upgrading RB25det Internals,
The week link in an rb25 motor is usually the Ring lands on the standard pistons, and the Con-Rods once you start pushing serious power out. It becomes a reliability issue, to upgrade the rods while you’re doing the pistons at the same time.
I know of many rb25 motors pushing rods out the block that’s why a cheaper alternative is to upgrade to the Rb26 Rod system. So you don’t have to incurring the cost of forged items up front.
The crank as many other people all ready know, is a reasonably strong item in the rb series motors. That’s why it doesn’t appeal to skyline owners who want reasonable horse power on a low budget. As Jun has stated the cost of a crank from Japan isn’t cheap. And not viable until your planing on competing against GTR700.
The actual size of the rods dose not determine its strength. If you compared the standard rb26 rods against the forged rb26 rods they are not really that much bigger in physical size, What actually makes them stronger is the material compound they are made out of. Hence the process of forging.
As for rod bolts you would be crazy not to replace them with New blots or at-least ARP blots to sustain the integrity of your motor.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
