Hi,
so now I have all of your attention, I was wondering if I could pick all ya brains on something.
I am buying a r33 gtr, (rb26) and had a compression test done on it and the results were as follows (psi) 105, 105, 105, 110, 125, 110, now the mechanic said that was good.
and as I belive it, it is good as the lowest reading is more than 75% of the highest, but I was wondering if the over all (psi) was to low, ie. I have herd the rb26 is suposed to have 171 psi as a factory fresh motor, if this is the case than is it right that the motor has droped that much compression in (an aparent) 66,000kms.
Im a little parinoid, as Ive never spent sooo! much money!!
any advice would awsome! :P
https://www.sau.com.au/forums/topic/51990-nude-chicks-posing-on-skylines/
Would be better to post what you want but anyway..
The figures sound very low for a RB26 engine. I would suggest up around 150ish to be more in keeping with the mileage.
A cylinder leakage test is better indication of wear plus it gives an idea of where the problems may be by where the air leaks out.
I would suggest taking it to a w/shop experienced in dealing with these type of vehicles .
If your NOR , come to see us, if SOR SST is probably the go. There are other shops but both of us are SAUWA sponsors and try to look after our members.
Cheers
Ken
Mark, I agree with GTRKEN's analysis, but it is also the spread of compression that is important not the actual figure necessarily. Depends how many cranks they allow while doing the comp test. The spread between 125-105 isn't too bad, but as suggested a leak-down test may show more.
Cheers
Paul
Hi there, I bought my r32 gtr august 2003 and it had 108k on the clock. A compression test came back with all 6 cylinders being between high 150's and low 160's. Maybe use this and other peoples info as a comparison :)
    • What's on the front of their building?
    • Jax Tyres Smithfeild Ive gone there a few time, well for tyres. on my 3rd visit I spoke to the dude and told how i just got slugged for rotors, brakes ect. His reply was golden; have you read whats on the front of the building. Never forgot it.       before picture, good friend got all these goodies installed.  Well time to study, servicing, maintenance all before this weekend driving lesson.
    • Hello, first of, I’ve looked at many threads on this code but none have helped me, if you know one that will help me feel free to post a link.   Now to my problem. Recently I was driving and noticed the check engine light came on. I went home and did the test to see what code it gave. I got the 21 code but everything seems fine with the car, no misfire, idle is good, acceleration is the same as when I bought it. I mean no signs of obvious failure. If no misfire is happening I can rule out the coil packs right? Which is about 98% of posts saying it is. If anyone has had this happen and found the issues let me know please. No other lights are on.   The car WAS due for an oil change. I since then changed it so idk if that triggers code 21. Either way it hasn’t turned off.
    • Your both right, it may hold a bit longer then.  Soon I need to change the synchros, should I fit the billet plate while I'm at it? Or just a waste of money?
    • Some of the east coast US Stagea got together this past weekend at Lime Rock Park in CT for Grid Life Circuit Legends. This is probably my favorite pic of the shoot with @Morgan.Mundahl on IG. Hope we get more stags out next year! i think I spotted 5 other than my own at the event.
