1995 Skyline R33 GTST , Type M ( White) Manual
Series 1.5
This car is in great condition.
Rare Factory Sunroof
Exterior
- Mspec Wing
- Mspec Sideskirts
- Gtr Front Bar
- Veilside Rear Bar
- Sunroof
- Volk Challange Forged Light Weight (17x 8 & 17 x 9)
- Sumitomos all round with 80% tread
- Philips H1 5000k
Interior
- MoMo Apache Steering wheel
- GTR Instrument Cluster
- Trust Gear Knob
- Custom red leather shift and brake boot
- Sparco Pedals
- Panasonic Head Unit
- Alipine rears and front splits
- Us Audio Compe Amp(1200watts)
- 12 inch Pioneer compe sub
Car is clean as it can be
Mods
HKS 2535r Hiflow Ballberring Turbo
Trust Front pipe and Dump pipe
Os Giken Ex Cam
Z32 Afm
Apexi Hiflow Filter
Nismo 555cc Injectors
Bosch 550Bhp Pump
Apexi Power Fc With Hand Controller ( Limited D1 Edition )
HKS Super Dragger Cat back Exhaust 3 "
Big Hiflow 3"cat
Excedy Twin Heavy Duty Clutch
Red Line Bushes
Custom RHK Front Mount
Anodised Red Light weight Intercooler piping
Blitz Turbo Timer Fatt2
Blitz Temp Gauge
Greddy Boost gauge
I think i left out some but thats all for now ,
This car always serviced every 5000ks maybe less
Just had all belts changed , original nissan belts with receipts.
This car has been my baby.
Comes with rwc and rego till nov 2005
Oh yes , car comes with almost all stock parts , including stock Body kits.
Including Stock ECU , injectors , etc etc…
When I got this car it was dead stock. All mods done this year. Turbo not done more then 10000k
Everything is mostly brand new.Need to sell asap , leaving Melbourne.
Asking $24500 ono
Offers???
Or Without Mods (Offers)?
$19500 for standard which still includes rims , intercooler , exhaust system etc etc
https://www.sau.com.au/forums/topic/52009-r33-gtst-type-m-white-240rwkw/
I Have Access To 20k But Id Want The Whole Car With All Mods. Pm If You Are Keen
20k is a little too low , all mods are almost brand new , all done this year.Maybe if u could offer a little higher !Im not asking skyhigh prices as i need to sell asap.
Hi Skynuts nice car, just a couple of quick Q's if you don't mind
Doesn't the 2535 have a T25 flange and the R33 a T3 flange? if so do you have an aftermarket exhuast manifold or just adapters? and what about the dump pipe flange?
How response is the 2535r does the boost start to kick in around 3500, 4500 etc ?
And can you please post some pics of where the temp gauge and boost gauge are mount plus a pic of the center console and the gtr instument cluster.
Hope thats not to much of a strain. :)
Cheers
Dori
i have sent u pm , anyway the turbo is well known for quick responce , thats wat makes it one of the best drift turbos, it starts spooling at 2900 revs. Thats not laggy at all. so yeah ...
Anyone??? Price is ONO !!!!
Dori
You can get a 2535 with a T3 Flange.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
