  • Replies 46
CRD are one of the preferred Power FC tuners in Sydney, however they will most likely require your car for the best part of a day to do a comprehensive tune - 9648 4264
Unique Autosports in Castle hill are also very good with Power FC's - 9634 8000
Both are open weekends
Hey Burto
I would definately suggest that you go to Sydney. We have never had good experiences with tuners in Newcastle. Also, there are no 4 wheel drive dyno's for your gtr (pretty positive) in Newcastle. I always take my car to CRD. It's worth the drive and the $$. Even if it does take most of the day you can hang out there and check out all the cars, or go and see the sights of Sydney (seeing you have just moved over here).
Cheers
I had my SAFCII Dyno tuned @ Pulse Performance in Newcastle. The tuner there is meant to be good *I had great results with them* & they do sell and tune Power FCs. One of the guys @ Pulse owns a 430rwhp r33 GTST *stock internals im pretty sure* & i seen another 2 skylines in the shop being worked on when i was there too *a r32 & 34 GTR*.
Look up Pulse Performance in your White Pages i guess, they are in the yellow pages too.
The only workshop to trust in Newcastle in terms of tuning Power FC is Premier Exhaust & Performance.
Rodney used to work for Dave Alexander (Silverwater Automotive Services) so he performs a pre dyno checkover. They put the car on a truck and the car is tuned in Sydney at Sliverwater Automotive Services and returned to the workshop in Newcastle. It takes the pain out of getting to and from Sydney and it gets you to jump the waiting list...
I would definitely reccomend this way as i did it and was very very happy with the results (440 HP at all four wheels). You would be surpised how many cars initially tuned at CRD end up in the hands of Dave at Silverwater Automotive.
Go see the boys at Ferry Rd. Sandgate, theyll helpy you out.
TANKX 4 that 1 mate ive herd of dave and he has worked on great coomo's and i would love 4 him 2 work on my r32-got a number 4 me -mate
If you dont feel like going to sydney & probably paying bigger bucks, Check out Pulse Performance on Broadmeadow Rd. I've just got retune with them & very happy with the results, the Tuner there is Josh & he know's his shit with Power FC's. I highly recommend you give them a ring. 4962 4972
Owww & my latest Tuning results is located here
http://www.skylinesaustralia.com/forums/sh...d=1#post1041096
Cheers,
well scotts dyno got  165.2 @WHEELS FROM MY R32------- u r from newcastle --yes
I can honestly say that pulse performance do a great job....and josh there certainly knows power fc.
I have been sooo burned by shops in newcastle before....eg.....yeah we can tune ya car then later that day getting calls saying ya car was spotted in sydney then finding out later it wasnt tuned down there...ah so nice of them to clock the kms up and add that bit extra onto the bill.
Pulse have been pretty straight up....no bullshit.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
