Hi everyone ;)
After talking to a few ppl, I decided to come back and join the forum. Alot of people here will know the old car (and what happened to it :D ):
I considered an R33 GTS-T as a replacement but really not the kind of car I drive. Its not that I don't like skylines (if i didn't why would I be here lol), its just not my style. In the end I found a car I really like. This is the new car:
I picked it up pretty much stock excpet for superlow springs and the chrome wheels. I got rid of the superlows and stock shocks right away. Following in the same style as the Mirage, the car now rides on koni coilovers. It's also had a rear strut brace, adjustable rear sway bar, front castor kit, and rear camber kit installed. The tyres were replaced with Yoko ES100, and kevlar brake pads all round.
Anyway I hope the sight of a Honda in this thread dosen't offend too many people. I have always appreciated SAU as one of the few remaining forums for true motoring enthusiats.
https://www.sau.com.au/forums/topic/52200-new-member/
its definitely got *bling*. Those del Sol's can go ok with a few mods.. fairly rare too.
Yeah the bling bling wasn't my choice :Oops: But these cars are rather hard to find so you have to take them as they come. The heavy chrome wheels will be comming off when I have the funds for something else, but the suspension work had to come first. Stock performance is ok, since it's got the B16A motor in it. They usually run in the 15's. Anyway experience with the mirage has shown that there is more to going fast than the 1/4 mile.... Ohh and I love how you can drive around for a whole week without seeing another car the same ;)
https://www.sau.com.au/forums/topic/52200-new-member/#findComment-1029479
Plus the Mirage held up quite good considering what speed you were doing when it abruptly came to a sudden stop! You were quite lucky to walk out of it I reckon! Damn Urban 4x4's, they should be banned! You know in California there are over 33 MILLION SUV's!!
And yeah I couldnt lose it on some of the mountains we went driving on! :)
Welcome to the world of oversteer!
https://www.sau.com.au/forums/topic/52200-new-member/#findComment-1030008
WB mate, yep the ole' mirage went pretty well through the twisties. I agree whole heartedly, suspension first.....It what I always do, so it must the right thing to do, haha. I am sure the new wheels will handle pretty damn well to, although some nice spoon manifolds and stuff would be nice too :) hehe
https://www.sau.com.au/forums/topic/52200-new-member/#findComment-1030851
Hahaha those JDM bling bling honda parts are not cheap! Mitsubishi and Nissan parts are cheap in comparison... For example, a quad throttle setup for the mirage was going to be just over $2k. Same thing for the Honda is $5500! And the price the honda people will pay for a set of headders :uhh:
Anyway I'm pretty happy with the handling now. Just fine tuning the settings a bit. It actually feels quicker than the mirage, which I never thought it would (the sol is a heavier car, plus the targa roof should make it less rigid).
Charly: Yeah thats the gremlin lancer in the left of the photo
https://www.sau.com.au/forums/topic/52200-new-member/#findComment-1030910
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
