R33 Reverse EL Dials
dazsQ
 Share
  • Replies 204
you have put them on over the needles?
Hi Guys,
I have put them on on tuesday night and after picking them up of Daryl at 11pm (sorry for the lateness dude) and finished by 1:15am.
they are awesome.
Yes yo uhave to slip them THROUGH the needles and then press the entire el dial down to slide under the needle to allow the bum end of the needle to fit through.
Also, i took the power off the cigerette lighter, black on the black, and red off the red/blue going to the light AROUND the lighter.
One thing i have noticed though, is that i cannot see the bluddy needles at night. are they supposed to light up or something? i have to look for the black shadow to see what speed i am doing and also, i cant see the needles forf the fuel, temp and oil gauges.... help?
Vape
Alright people!
Here are my images taken just now after rerouting the cabling so that the bulbs are back in.
I found that the needles were way too dark, especially when there were no street lights!
I have found that there are holes on the back of the dash cluster for holding cabling against it. I removed the connectors from the leads and thread the cables through these holes, then connected the connectors (?) and was still able to use the bulbs for the needles.
Hope you all have success the first time... !
 Share
    • Slap a 460L into the car, send its mum.
    • So last night pulling away from the lights, I lost power for about 1 second. Bit weird, but I kept driving... 5 minutes later the pump completely dies. When I tried to start the car, the pump won't even prime.  I left the car for about an hour, tried to start it and it all appeared fine. Pump primed, car started, got the fuel pressure I should have.... Start driving home, 5 minutes later it dies again. I'm stuck in a shit spot this time going up hill with a car right behind me, so I just let the car continue to turn over while praying to the fuel pump gods. After about 2 minutes of turning the engine over, the fuel pump came back to life and I got home (only about another 5 min away).  So I've been digging around online, it seems like the 525 fuel pumps really don't like to be run at 100% all the time. I've found quite a few examples online of people killing their Walbro 525 pumps within about a year of usage when they are run without PWM.  So, my pump is an Aeroflow 525 (AF49-1057) and I've been running it at 100% without PWM. I'm thinking the Aeroflow 525 didn't like being run at 100% and has burnt itself up.  I really am sick of dealing with fuel pump issues, my current thoughts are -  1. Use a Walbro 450 and run it without PWM. It seems like these pumps hold up pretty well to being run at 100% all the time. I only make about 350kw and can't see me making any more power any time soon so this is probably a fine option.  2. Get a Walbro 525, run it with PWM. I know doing this will annoy me as I feel like with only 350kw, its extra expense that I don't "need" and I'll be thinking the whole time while setting it up that I should have gone with option 1. I know I'll be happy with this option when its setup and running, its only the initial setup frustration and cost as an issue.  3. Get a Walbro BKS1001 brushless pump. This is the fu*k it I'm already going PWM, might as well go full retard. This option just seems better in every way, with the only downside being cost. But I don't know much about this pump so I could be wrong.  Happy to get everyone's thoughts before I go digging around in the fuel tank again.
    • Doing it this weekend. For sure this time. Thank you forum gods.  And im running map sensor now with the haltech. Still have the AFMs attached to the mushroom dome shaped air filter things
    • Actually, it is probably pretty legit. I mean, it's still woke feminazi bullshit academia, but you would have to agree that it is very likely that there would be a correlation between wanting a loud exhaust and scoring at the unpleasant end of the scales for dark triad personality traits. The fact that they found it didn't correlate with narcissism and only with psychopathy and sadism definitely shows that the loud exhaust thing is more of a "f**k you" than a "look at me", and I reckon that rings pretty close to most of the dickheads who take it to the extreme. Remember, this is correlation with tendency to be closer to one end of a personality trait scale than the other end. Of course someone who is at the literal opposite end of the psychopathy scale is going to be so considerate of others that they wouldn't even think about wanting to upset anyone with a loud exhaust. So the finding isn't that "you are a psychopath". Just that you score more towards that end of the scale than someone who doesn't like loud exhausts (on average, not necessarily even for specific individuals).
    • Blitz ER34 at some point hopefully, should be allowed in Gr3 if they do.
