Thinking it wasnt such a good idea... as i disabled the battery... and the alarm went off (forgot to get the alarm key which is in my desk inside) this is at... well now 1am... so it would technically have been 1am when i did it an hour ago... damn daylight savings.
5 mins it was screaming its head off for... it took me ages to get back in the house as i went out the side door and accidentally locked it behind me... only house key i had on me was for the front door... which had a chain on it unknown to me so i had to run to the front door... find it was chained and then run back thru the gate which takes ages to open and in the side door which was locked! luckily everyone was awake by now and let me in lol
anyway... after i finally turned the volume off... i disconnected the battery and pumped the brakes for like a minute just to make sure it was fully drained, reconnected it and took off to the lovely 4 lane wide 1km long back streets that dingley has to offer for about 20minutes... giving it hell the whole time.
i dont know if im imagining things or if it has done something... but it seems to rocket a lot more than what it normally does.... it cant be the cold air cause i always drive it at this time of night as i finish work at 12am. maybe its in my head but if i give it a bit of a launching it seems a lot smoother than it did and seems to go a little harder.
i'll see what its like during the day tomorow.
https://www.sau.com.au/forums/topic/5253-just-reset-my-ecu/
I'm not sure if it really did anything too. I had it reset, thanks to the assistance of the good Dr with the right tools. Doesn't seem to really make a difference. Does it self learn as we all believed? I'm more inclined to think that the newer 33s would have self learning computers.
Anyone can give some input on that?
https://www.sau.com.au/forums/topic/5253-just-reset-my-ecu/#findComment-82711
it all depends on how badly tuned ur car is in the first place... mine was nasty :P taking off was just sluggish to the max... 1st and second felt like taking off in 3rd and 4th but now it doesnt.... it takes off like it should. Its done something all right.
obviously if ur car isnt that bad in the first place it wont do anything and it will also depend on how long u drive it for.... u cant reset it and start driving it like a grandma for 5 mins... i gave mine a severe thrashing... 8 grand revs every gear til i hit the speed limiter down the Westall Ext at 1am/2am
https://www.sau.com.au/forums/topic/5253-just-reset-my-ecu/#findComment-82719
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
