R32 GTR test drive
Originally posted by GTRKING
Does he STILL have the silver one with all the mods?
If so he has had that car for more than a year now!!!
and has used it on the track numerous times.
LOL... About 6 months ago I was going past Phillip and that silver R32 GTR pull out of the car yard and he gave it a bit. Then when he saw me putting along in my GTS-t he gave it heaps, and I mean HEAPS.
Now I'm not sure if it was cold or what, but the amount of black smoke that came out of the exhaust was amazing. It looked like the Batmobile there was so much smoke!!!!
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-81817
all gtr's either 32, 33, or 34 blow black smoke when hammering (i know i own one) the rb26 motor u could say is similar to a rotary engine by that i mean they love to rev the more it revs the more it burns oil thus u get the black smoke out the back, it's normal u just gotta check the oil and change it regularly.:D
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-82129
Whytry,
Well I'd have to disagree with you on this. I have owned
a 97 33 GTR-V for 2 1/2 years and currently drive a 92 32
GTR and in all the time I have owned them neither blew
copious amounts of black smoke under load and by that
I mean dancing on the red line. especially the 33.
Neither were heavily modified thou! and when you
start playing with the computers etc they tend to
run pretty rich to protect the engine this adds to the
black smoke "stealth" effect :D
ohh and if your oil is cold any car will blow weed! but
I do know that the silver 32 in phillip is a heavy smoker
all the time!!!
R,
Adrian
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-82138
nope mine is red with gold rims just got it back on road after 6 months in workshop getting 'mods' has at moment QLD rego but i'm changing it to N.S.W. rego soon after i 'run' in motor, it's an r32 gtr.
was out and about tuesday night and last night, around civic, woden and manuka.
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-83067
nah that gunmetal one is mine, i only drive it to uni,so thats why its always on william slim. Hey Goran how you goin im the guy that rang bout the power FC. You car is so sweat i wnat you to take me for a drive when jake has it all finished off. He is doin some stuff on mine after some disapointing dyno results that were no were near where they should be we should catch up some time!!
Daniel
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-83373
hey daniel
yeah for sure i'll take you for a spin, i'm just waiting for the hand controller to come in.
yeah jake was telling me he too was dissapointed in the results, but that ok till you get it sorted out properly and hell when u do man that thing WILL absolutely haul some serious butt.
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-83452
Guest thedriver
neergnevets -
Well I got into a R32 GTR and let me tell you.. they are small and tight.... obviously designed for Japanese in mind...a lot smaller than my Mx6.
The R33 is a lot bigger and roomier inside. Even the more open dash plan makes it feel larger. This seems like it was taking into account they may be exported to the rest of the world.
So it's back to the R33 for me... will have to save some more!
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-87275
I sold my MX-6 yesterday! I had to drive it to the buyers
house, so I went straight form the GTR (32) to the Mazda.
I honestly didn't think that their was that much difference? I guess if you've got a sunroof in the MX-6 open you could stick
ya head out!!! :)
Is anyone interested in a track day?
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-87315
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
