R32 GTR test drive
Originally posted by GTRKING
Does he STILL have the silver one with all the mods?
If so he has had that car for more than a year now!!!
and has used it on the track numerous times.
LOL... About 6 months ago I was going past Phillip and that silver R32 GTR pull out of the car yard and he gave it a bit. Then when he saw me putting along in my GTS-t he gave it heaps, and I mean HEAPS.
Now I'm not sure if it was cold or what, but the amount of black smoke that came out of the exhaust was amazing. It looked like the Batmobile there was so much smoke!!!!
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-81817
all gtr's either 32, 33, or 34 blow black smoke when hammering (i know i own one) the rb26 motor u could say is similar to a rotary engine by that i mean they love to rev the more it revs the more it burns oil thus u get the black smoke out the back, it's normal u just gotta check the oil and change it regularly.:D
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-82129
Whytry,
Well I'd have to disagree with you on this. I have owned
a 97 33 GTR-V for 2 1/2 years and currently drive a 92 32
GTR and in all the time I have owned them neither blew
copious amounts of black smoke under load and by that
I mean dancing on the red line. especially the 33.
Neither were heavily modified thou! and when you
start playing with the computers etc they tend to
run pretty rich to protect the engine this adds to the
black smoke "stealth" effect :D
ohh and if your oil is cold any car will blow weed! but
I do know that the silver 32 in phillip is a heavy smoker
all the time!!!
R,
Adrian
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-82138
nope mine is red with gold rims just got it back on road after 6 months in workshop getting 'mods' has at moment QLD rego but i'm changing it to N.S.W. rego soon after i 'run' in motor, it's an r32 gtr.
was out and about tuesday night and last night, around civic, woden and manuka.
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-83067
nah that gunmetal one is mine, i only drive it to uni,so thats why its always on william slim. Hey Goran how you goin im the guy that rang bout the power FC. You car is so sweat i wnat you to take me for a drive when jake has it all finished off. He is doin some stuff on mine after some disapointing dyno results that were no were near where they should be we should catch up some time!!
Daniel
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-83373
hey daniel
yeah for sure i'll take you for a spin, i'm just waiting for the hand controller to come in.
yeah jake was telling me he too was dissapointed in the results, but that ok till you get it sorted out properly and hell when u do man that thing WILL absolutely haul some serious butt.
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-83452
Guest thedriver
neergnevets -
Well I got into a R32 GTR and let me tell you.. they are small and tight.... obviously designed for Japanese in mind...a lot smaller than my Mx6.
The R33 is a lot bigger and roomier inside. Even the more open dash plan makes it feel larger. This seems like it was taking into account they may be exported to the rest of the world.
So it's back to the R33 for me... will have to save some more!
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-87275
I sold my MX-6 yesterday! I had to drive it to the buyers
house, so I went straight form the GTR (32) to the Mazda.
I honestly didn't think that their was that much difference? I guess if you've got a sunroof in the MX-6 open you could stick
ya head out!!! :)
Is anyone interested in a track day?
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-87315
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
