R32 GTR test drive
Originally posted by GTRKING
Does he STILL have the silver one with all the mods?
If so he has had that car for more than a year now!!!
and has used it on the track numerous times.
LOL... About 6 months ago I was going past Phillip and that silver R32 GTR pull out of the car yard and he gave it a bit. Then when he saw me putting along in my GTS-t he gave it heaps, and I mean HEAPS.
Now I'm not sure if it was cold or what, but the amount of black smoke that came out of the exhaust was amazing. It looked like the Batmobile there was so much smoke!!!!
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-81817
all gtr's either 32, 33, or 34 blow black smoke when hammering (i know i own one) the rb26 motor u could say is similar to a rotary engine by that i mean they love to rev the more it revs the more it burns oil thus u get the black smoke out the back, it's normal u just gotta check the oil and change it regularly.:D
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-82129
Whytry,
Well I'd have to disagree with you on this. I have owned
a 97 33 GTR-V for 2 1/2 years and currently drive a 92 32
GTR and in all the time I have owned them neither blew
copious amounts of black smoke under load and by that
I mean dancing on the red line. especially the 33.
Neither were heavily modified thou! and when you
start playing with the computers etc they tend to
run pretty rich to protect the engine this adds to the
black smoke "stealth" effect :D
ohh and if your oil is cold any car will blow weed! but
I do know that the silver 32 in phillip is a heavy smoker
all the time!!!
R,
Adrian
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-82138
nope mine is red with gold rims just got it back on road after 6 months in workshop getting 'mods' has at moment QLD rego but i'm changing it to N.S.W. rego soon after i 'run' in motor, it's an r32 gtr.
was out and about tuesday night and last night, around civic, woden and manuka.
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-83067
nah that gunmetal one is mine, i only drive it to uni,so thats why its always on william slim. Hey Goran how you goin im the guy that rang bout the power FC. You car is so sweat i wnat you to take me for a drive when jake has it all finished off. He is doin some stuff on mine after some disapointing dyno results that were no were near where they should be we should catch up some time!!
Daniel
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-83373
hey daniel
yeah for sure i'll take you for a spin, i'm just waiting for the hand controller to come in.
yeah jake was telling me he too was dissapointed in the results, but that ok till you get it sorted out properly and hell when u do man that thing WILL absolutely haul some serious butt.
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-83452
Guest thedriver
neergnevets -
Well I got into a R32 GTR and let me tell you.. they are small and tight.... obviously designed for Japanese in mind...a lot smaller than my Mx6.
The R33 is a lot bigger and roomier inside. Even the more open dash plan makes it feel larger. This seems like it was taking into account they may be exported to the rest of the world.
So it's back to the R33 for me... will have to save some more!
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-87275
I sold my MX-6 yesterday! I had to drive it to the buyers
house, so I went straight form the GTR (32) to the Mazda.
I honestly didn't think that their was that much difference? I guess if you've got a sunroof in the MX-6 open you could stick
ya head out!!! :)
Is anyone interested in a track day?
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-87315
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
