Fitting 550cc Supra 2jz turbo injectors into a RB25det
Guest darrinspencer
I am looking into the "posibility" of fitting Toyota Supra IV twin turbo USA spec 550cc injectors into a RB25det.
Japanese spec are 480cc.
The injectors are low impedence, but RB25 use high impendence
Is there some way of re-wiring etc to get these to work?
Will they fit into the fuel rail with little to no mods?
I have a new Wolf plug-in ecu, which is not fitted yet, will this be able to run low impedence injectors instead of high impedence?
These injectors can be found for about $150 aust., hense the consideration in finding out if these will work
Has anyone tried these?
Attached is a photo of what they look like the blue set of six
Also attached is a photo of nismo 555cc injectors, just to compare
Dunno if they would fit, they look alot like RB25 injectors though
If they are low impedence, you could wire in a GTR resistor pack and it should work fine
Chris
Guest darrinspencer
They look too large at the base to fit in the RB25 rail. Have you looked into 550cc 20B cosmo injectors?
I have, but they are hard to get and are nearly as dear as buying s/hand Sard etc rb25 injectors, also the WRX boys want them
Yes they will fit with a little effort and the wolf Plug in will drive them with no problem with out any need for a resitor. If you have any doubts email Wolf in Australia and say Steve thomas from SST told you the wolf will drive these injectors.
So are you using these in a RB25det?
If you are, what was needed to make these work.
Steve- thanks for the answer.
I'm using these in an RB30DET with the R33 head. I machined up some aluminum collars to locate them centrally in the bowl. A small amount of material needs to be removed from the bottom filter cage and aluminium tip so they will fit into the bottom of the bowl. Plugs are different. Rather than "cut and shut", i bought new terminals and plugs and re-crimped them.
They are high impedance (13 ohms i think).
Guest darrinspencer
The US spec are low impedance.
What computer are you running?
I think we have a communication breakdown here.....
To clarify, I have 20B cosmo injectors which i sourced from dysons and a rotary forum. These are high impedance. I machined up collars to fit these in the r33 rail as i mentioned above. Computer is Haltech E11.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
