Just a question about camber kit
I have a vibration on braking, but no pedal pulsing.  My mechanic said
that it may be the upper control arm bushes are worn.  I think the camber kit
will replace those the the offset bolt and new nolothane bushes.
Can I kill 2 birds with this one.
cheers
If it is bushes, then most likely caster (front of radius arm) bushes as yhye get dragged whne you brake. But personally I reckon it's rotors, standard Stagea brakes are ....well .....not up to my driving style. The rotors warp pretty easily.
:D cheers :D
Hey SK Can you check your POSTS #81 and post #86 as the pics are not there and they will be needed for a lot of us.
Thanks
Lost links when the forum was upgraded, fixed now, thanks
:P cheers ;)
This is the brake hose bracket on the front, because of the lower spring seats on the Bilsteins there are no brackets on the shocks to bolt it to. So I just used a couple of larger cable ties around the shock to hold it in place. There is no real load, it more of a spacer than a load carrying bracket.
As you can see I have installed the Whiteline coils, in place of the standard ones I have had with the Bilsteins for the last few months. I will be fitting the R33GTR 17 X 9 X 30 wheels tomorrow with 245/40/17's and I thought it needed to be a bit lower to suite them. I couldn't go any lower on the rear with the standard springs as the offset of the GTR wheels meant the lower spring seat was too close to the inside of the tyre. So I needed to use a shorter coil. Plus I was worried that the standard spring rate wouldn't carry the trailer weight being that low. Since I was changing the rear springs I figured I might as well do the fronts as well.
The Whiteline coils give a 30mm lower ride height than the standard springs. Which is a bit low for what we use the Stagea for, so I raised the lower spring seat circlip up one groove. That gave me 355 mm centre of wheel to guard, I reckon it will settle to around 350 mm which should look good with the bigger wheels. I will post up a picture when it is finished.
:D cheers :O
Edited by Sydneykid
A few guys have asked me about getting acces to the rear shock tops. You have to remove the plastic cover, it has a single 10mm bolt hold it in and 2 clips. You just pull straight up to unclip it, once you have removed the bolt.
There is a rubber cover over the shock top and its 2 X 12mm retaining bolts. Just pull up the rubber cover, its a tight fit.
Then undo the 2 X 12mm nuts, be careful, don't drop them down behind the trim, it's a bugga to get them out.
Tools required = 10 mm socket and 12 mm socket with rachet drive
:P cheers :D
Edited by Sydneykid
As promised some pictures with the Whiteline coils fitted. The front is 340 mm centre of wheel to guard and the rear is 330 mm, this gives a 15 mm rake towards the front (ie; nose down).
As you can see the 245/40/17's are a bit small in diameter for the large Stagea guards. I reckon 245/45/17's would fill the guards a little better.
The look I like is along the side of a car, where the wheels are in line with the bodywork;
The standard exhaust is a bit low at 340/330 mm so I am going to raise it up 1 circlip groove (ie; 350/340 mm) for the 3.25" exhaust which is going on next week (finally).
Now I know why Autech used the R33GTR wheels on the 260RS, I reckon they suite the Stagea shape very well.
:P cheers :D
Edited by Sydneykid
BTW, interesting that your stagea is a days edition, but lacks the sideskirts and rear dayz bar?
Still, looks good with only the front bar
Yep, I like the front bar, rear bar and the rear spoilers as they are, I wouldn't mind a set of small side skirts though. The extra width of the Stagea cabin on the narrower R33 4door floor pan means there is that noticeable tuck in under the doors. A set of skirts would fix that, provided that they aren't too deep as that would make the front and rear bars look out of place. So I think the 260RS side skirts might be a bit too big, do you have any pictures of the Dayz side skirts that go with the front bar?
:P cheers :D
here ya go
http://www.skylinesaustralia.com/forums/in...topic=78854&hl=
I think, instead of us all getting 260rs kits, maybe we can get copies of days made
Yea the DAYZ edition bodykit sounds like a pretty good idea ;) Will probably make it a bit cheaper for us as well, although they dont look as good. I would prefer a 260rs kit, but this sound like a pretty good substitute B)
Some people have had problems reading/understanding the Whiteline instructions for the rear subframe bushes. Courtesy of Emanuel, I have numbered the bushes in the pictures and numbered the corresponding bushes in the Whiteline instructions. If you are lucky I have got them right, it is so much easier when I am actually doing it. Please do a quick check just to be sure.
It's a bit hard to draw #3 as it goes above the sub frame, which you can't see in the picture. The bushes that go above the subframe have cuts in them. This is so you can slip them over the bolts/studs and don't have to remove the whole subframe to do it.
:P Cheers :)
Edited by Sydneykid
For completeness, I have marked up the subframe pictures supplied by Emanuel to show front and rear camber kits, the front caster kit and the rear subframe alignment bush locations.
The first picture is the front suspension;
The red dots show the location of the caster bushes ie; in the the front of the radius rods.
The yellow dots show the location of the camber bushes ie; in the upper control arm.
The second picture is the rear suspension;
The yellow dots show the location of the rear camber bushes ie; in the upper control arm inner. This is the location used if you only need one camber kit (ie; not lowered a lot).
The red dots show the location of the rear camber bushes ie; in the upper control arm outer. If you need 2 camber kits (ie; lowered a lot) then you will need to fit the second camber kit here.
The green dots show the location of the rear subframe alignment bushes, remember some can go above the subframe and some can go below the subframe, depending on what geometry you want. Please review the previous post for details.
Hope that was of some help
:( Cheers :)
Edited by Sydneykid
  • 3 weeks later...
Well, i've finally come to the end of my saga. ever since i had my coil overs and whiteline sway bars and camber kits installed my car has had a viscous pull to the left. i took it back to the guy numerous times, but he said the front wheels were aligned fine, there was no issue.
Getting rego inspection today at marc2's shop, found out my rear left wheel is 12mm toe in. i think this would account for a bit of a pull to the left. not only that, it's killed my rear tyres.
so when/if you get suspension installed and they say it's straight, ask them to check the rear wheels too, because this stumped me for a while.
end rant
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
