Well I'm not planning on lowering it for the time being, I may decide to one day maybe but I have already scraped the front bar comming in and out of some places (they have been a little steep though) and I do take the car on holidays and camping etc so I will probably just fill the guards with wheel size rather than lowering it.
But if the standard Nissan ones will cost more than the Bilsteins (and I'm guessing there is no aftermarket equivilent that are properly valved for Stagea's and not just GTR / GTS-T combo kits) then will the Bilsteins be fine with the standard springs (this may seem like a dumb question, but I'd rather be sure as suspension isn't one of my stronger points :) ).
Thanks again guys.
Yes, I ran mine for several months like that. I used the additional circlip grooves on the Group Buy Bilsteins to lower it, around 24 mm worked OK.
:P cheers :)
I dunno where this belongs
But
Any S chassis or Skyline diferential works in the stagea
I put an S13 differential in my stagea
ALl i had to do was change the input shaft for the driveshaft
and the rear cover
THen just bolt it up
you do need to find shorter bolts for the front two mounts as it will mount directly to your subframe now.
Hi SK,
what if the stock runs out for the blistein for the stagea? Will i be able to get hold of it later on down the road? Say next year?
Also howu much in differnce in price between a whiteline and einach springs? Much difference in performance?
Edited by stasis
  • 3 weeks later...
man im tellin you
my roads suck
like seroiusly dude
we have potholes, dips, crazy inclines everywhere
8/6 in a stagea is great
8/6 is too soft in a 180 to me so it is hella comfy in a car that weighs 1000 lbs more
man im tellin you
my roads suck
like seroiusly dude
i hit a bumpy road the other day traveling like 120kph and the car when all over the road!!! The suspension that i have now is JECS. And guess who OWN JECS?! Hitachi!! i think.
But yea i want to know whether with 8/6 will cause the car to go all over the road when it hit bumpy road at high speed?! Thats why Sk set up os very tempting. But the setup that i want is the one with eibach springs which costs like A$2.2k. That will have to wait till i saved up first.
your springs are like 40% of the equation
the shocks are the big thing
no matter what spring rate you have, if your shocks dont haev good bound and rebound dampning its horrible ride
well
tein is a good company becuase their valving and spring rates are more um.....less extreme
their valving isnt as harsh, and spring rates are normally 1-2k lower than other brands.
nope
all it takes is a few items
I tHINK the lower bolt is 19mm on front and rear (i think)
top 2 on the rear are 12mm
top 3 on the front are 14mm
and take it off
(after you take off wheels obviously)
nope
and take it off
ok thanks will try to change the suspension when i get the shocks late next week
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
