Do you guys know how the RB26 block holds up after sleeving?? and what horse power would the block handle after sleeving :goddam:
Depends on the quality of the sleeves themselves and the machining quality. As for power I have seen a sleeved RB26 make 1300 ps.:cheers
https://www.sau.com.au/forums/topic/53178-rb-26-sleeving/#findComment-1044784
Technically Keir Wilson + John Munro have got sleeved blocks, Keir's reported over 600kw at the wheels. Althought that's a bit off 1300ps.. Wonder how John's doing with his new methanol guzzling dry sumped motor?
DB, wins a chocolate frog for the right answer :rolleyes:
https://www.sau.com.au/forums/topic/53178-rb-26-sleeving/#findComment-1046417
Yes, the OS 3 Litre engine has a sleeved block, but much more engineering involved in sleeving all six & running a spacer plate due to the longer stroke. These engines are a work of art. Would seem simpler to me (if just looking to fix an RB26) to just buy a new N1 block & be done with it(thats what I have done on my street GTR)
As far as my "methanol guzzling" 3 litre goes - it has only guzzled about 1 litre so far - just been started to bring up oil pressure. The car is waiting for a few finishing touches ( as the $$$ allows - bit limited lately), but will hopefully be fired in anger before the end of the year.
https://www.sau.com.au/forums/topic/53178-rb-26-sleeving/#findComment-1053279
John
I read, heard, dreamt(??) that you balanced the brand new engine prior to running it?
Was this not already done by OSG?
https://www.sau.com.au/forums/topic/53178-rb-26-sleeving/#findComment-1053595
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
