I've a R33 full Explosive kit for series 2 for $850 new + postage, but the side skirts and rear bar will also fit series 1. If anyone interested or want to get more details about the kit, please email me to [email protected] or ring/message me to 0402 452 455, thanks.
*I also have a S14 Vertex rear bar for $350 new and 180SX front lip for $130 new.
https://www.sau.com.au/forums/topic/53227-fs-r33-full-explosive-kit-850/
The Explosive kit is similar style to the Vertex kit, but it is not as wide and low as the BN kit, only the side skirts and rear bar can fit the R33 series 1, but it is nice to match the kit with the Trust front bar. Please ask for photo or just leave your email here, thanks.
fresh & JaseR33, please check your email, and if you didn't get the photos, please let me know, and please reply to my email [email protected] and not here, thanks.
jager, are you Markus? Did you get my message about the Integra and Lancer bodykit? Does your friend still wants them? Please check your email too, I've sent you the photos.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
