  • Replies 67
okok...ill stop taking fotos of cars next time and just focus onthe chicks...
i figured I get photos of chicks all the time doing club photography it would be a change to get some cars...apparently not... sooo...chiks it is...
https://www.sau.com.au/forums/topic/53275-2004-motorshow/#findComment-1048912
hahah nah when i went there was a skinny blonde chick....except there was only one !!
assmon is the video of it show it being opened manually or is it automatic ?
i asked the girl if she could open the doors and she opened it manually.....
I would have thought for a 1.2mill car you would get automated doors like the Murceilago.
speaking of 1.2 mil i asked her if they have sold any....and she said they sold one yesterday...a orange one.......I cant comprehend that.....someone just came up to them and said..yep here is 1.2 mil......ill have the orange one thanks.....DAMN.
hahha damn mona your making me jealous of not having seen those chicks !!
but thats ok i was drooling over the rear end of the CCR with those FAT 335 rear tyres !! :P....baby got back....hahahhaa
https://www.sau.com.au/forums/topic/53275-2004-motorshow/#findComment-1050999
moanie:
the brunette chick was nicer personality wise...:P
shonen:
it was the doors closing, as for the doors opening, my digicam was still saving the file from the doors closing so i dind't get it:(
they sold 4 koenigseggs CCR when i went:) - would love to see one on our streets!
and no the doors weren't automatic - but they seemed very lite when she opened it!!
the only auto door i saw was the alfa!! it was the concept one due to release in 2006... all it does is pop out a little when u touch the button... lol... o yeh, i got to sit in it!!:) (a buyer was looking at it, so i asked if i can go in)
hehe
AssM@N
https://www.sau.com.au/forums/topic/53275-2004-motorshow/#findComment-1051214
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
