  • Replies 67
I remember seeing Missy Elliott on MTV Cribs, and she had a Ferrari shell with the guts chopped out (might have been a 355, but can't remember exactly), and she'd had it converted to a bed. A bed, dammit!!!
Where the front luggage compartment was, she'd had it made so the whole section rose up (there was no windscreen), and there was a plasma screen TV attached under there!!!
Beats any car racing bed I've ever seen in any shop or house, hands down!
Back on topic:: Motor Show wasn't all that special this year, must agree. Definitely some nice chicks around though, but that goes for just about every year. Who was smart enough to get photos of them? I only managed two, and I can't even remember what stand they were on...
I've uploaded my shots to the gallery.
Nick T
she had whole heap of sneakers in the boot as well which also rose up...
then outside in the parking lot, she had a hummer H2, and the green murcielago...
btw, i so so sooooooooo want that F355 bed... but then i guess i would have to have a road going one in my garage before i chop it in half and convert it to a bed... damn..$$$$$$ :confused:
hey!!! i recognise that chick from the konisegg stand( spell check)
she was featured in the autosalon magazine, last month's issue
its the blondie...autosalon model..drives a wrx sti...lives in brissie...cant remember her name...she was @ motorshow? awww..mustve missed her.
any of u guys gunna feature ur cars at the enxt autosalon show on 5th december?
  • 3 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
