Your so right, who gives a rats arse if its fair or not, just do as you are told, good boy - appathetic attitudes really piss me off - maybe you should become a cop, you seem to think that they are right regardless.
Fact - the SA POL DO NOT ENFORCE THE LAW, WITH REGARDS TO THE ROAD TRAFFIC ACT CORRECTLY,
Fact - TPT SA DO NOT ENFORCE VEHICLE STANDARDS CORRECTLY.
I have had enough of these forums
Take care all.
All the Road Traffic Act and Road Traffic Regulations say with regard to ride height is it has to meet ADRs and have a minimum 100mm clearance. How is that wrong or harsh?
  • Replies 50
Take care all.
OOOOK......................
Hey, this is reality and they are the RULES and regulations that govern this state. If you dont like it, do your little bid to fight their bullshit like you attempted to last time. Me personally, Ill do my best to keep my cars 'looking' legal. And the one that doesnt, ill just play the game of staying away. There are more serious matters in life to be whinging about defects on an obviously defective car. By the way, how did your little fight against TSA end up again????? :talk2hand
Then there's the 1/3 of suspension travel, then there's the minimum height your headlights must sit... If they don't get you on one thing they will get you on another *when they want to*.
Adam,
I actually hav'nt looked at the reg's for sa. however i do know that a 100mm block is passed under your car at a regency pk inspection and cannot foul anthing under your car-eg:exhaust, handbrake cables, electrical cables or suspension components etc..
Regards,
SKYLINE(Kym).....
Adam,
      Regards,
                  SKYLINE(Kym).....
When did I say it wasn't 100mm? I've said it is twice! It can foul under the car on a few things though
Ground clearance
 73. (1) In this rule:
"ground clearance", of a vehicle, means the minimum distance to the ground from a point on the underside of the vehicle, except a point on a tyre, wheel, wheel hub, brake backing plate or flexible mudguard or mudflap of the vehicle.
 (2) A motor vehicle or combination must have a ground clearance of:
(a)at least 100 millimetres at any point within 1 metre of an axle; and
(b)at least one‑thirtieth of the distance between the centres of adjacent axles at the midpoint between them; and
©at any other point—at least the distance that allows the vehicle or combination to pass over a peak in the road with a gradient on either side of 1:15, if the wheels of 1 axle of the vehicle or combination are on the slope on one side of the peak and the wheels of the next axle are on the slope on the other side.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
