Let's have a conversation in Japanese! (Romaji only)
  • Replies 105
maa betsu ni kyoumi nai kedo.. tada nihonjin nanoni nihongo ga shaberenai no wa chotto hen da to omotta dake..
Chotto hen na...
drift007, kuruma wo motteruka? sara ni doko ni sundeiru ka?
rexx san to onaji kuruma wo mottemasuyo. tokyo no machida shi ni sundeiru.. 2nen han mae kansai ni aru kuzuha to iu tokoro kara koko ni hikkoshi shita.
Ore no R32 to issho? Sugoi... drift007 no kuruma no shashin wo motteru? Hontoni mitaiyo! Tokoro de drift007 wa boku no koto wo machigatte "rexx" to yonda... :D
gomen shuchuu shitenakatta... moushiwake gozaimasen hehehe... mitakattara, ima norisuzukeruka, uruka wo mayotteru kedo toriaezu yahoo auctions ni dashiteru... http://page11.auctions.yahoo.co.jp/jp/auction/n6874019
maa boku no kuruma tte shokou ga nai kedo, moshi hoka no shashin ga hoshikereba ashita tottokimasu.
Suuuuugoi nihongo!!! Ima made jissho wo tsukawanakute mo ii kedo, saki no MESSAGE wa yomu toki hotondo wakaranakatta! :D
Tatoeba, "noriTSUzukeruka" ;) to "shOUKO" ;);) ga wakaranakatta. Boku no tsuma ga tetsudattekureta... anshin shita :cheers:
Motto shouko wa iranai desu :) tokoro de ii kuruma to omou, VERTEX no earo- (aero) ga kakkoii yo.
rezz mo nihongo jyouzu dayo. dore gurai benkyou shita no? boku no tsuma mo nihonjin dakedo au mae ni kore gurai nohongo ga dekita. nazeka to iu to kansai ni sundita toki no moto kanojyo ga kansaijin de shaberi ga mechakucha hayai!! sono toki kyoto no RYUKOKU daigaiku ni ryugaku shiteita kara ichi nen gurai no mainichi ga hotondo nihongo datta yo.. nihon no nouryoku shiken wo uketa koto wa aru?
Osoi henji wa gomen nasai... Go nen gurai nihongo wo benkyou shiteiru koto arimasuyo. drift007 wa "Kansaijin de shaberu ga mechakucha hayai" to ita... sou to omouyo!
Nihon no nouryoku shiken o mada toteimasen... jishin ga nai desu yo :D
  • 3 months later...
Ohayoo Rezz san, Hajimemashite maikelu desu. Watashi no nihongo wa choto wasulemashita kedo renshuu shimashoo.
Ima nani shiteru no?
Ohayo Maiku san. Ima shigoto chuu yo. Kyou shigoto ha 8 ji made yo... mou sude ni tsukareta... :)
Hey Justin,
Are you studying Japanese at the moment? Did you live there? Dont you think its a strange feeling speaking in Japanese to other gaijin when they already speak perfect English?
I'm not studying as such... more just practicing conversation now. Yeah, I live in Ashiya in Hyogo. I don't think it's strange speaking to other gaijin in Japanese *if* you want to practice... such as what we're trying to do in this thread :)
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
