Hey everyone,
Just curious, surely people here have owned / driven a RX -7 and was wondering what they think? im refering to like the 'newer shape' model MY1992+. How do they go? what you think of them?
I have never heard anything bad about them (except that the parts are pricey) and personally i think they look sexy! how do they compare with say a R33 gts-t? can they be compared with a GTR? post all your opinions!
I also noticed that they are still pretty expensive, even 1992 models go in the high 20's low 30's. why is that?
https://www.sau.com.au/forums/topic/53419-rx-7/
They are still expensive because they is no real import alternative, apart from private imports.
They go very well, running 13.9 1/4 stockers. You can get that down to run 10s with the standard turbos. Even down to as low as 11.2 with a standard fuel pump. Very, very nice cars.
13Bs are capable of 700rwhp.
https://www.sau.com.au/forums/topic/53419-rx-7/#findComment-1050221
the rotarys have gained a bad repetation for being unreliable. there were many exaggerated stories of the engines needing rebuilds every 5000kms. fortually these major prob were confined to the early rotaries, especially the 12A. the later model RX7s which had the 13B were fine as long as regular mantainence was performed. there appears to be no problems with the new series 6 onwards Rx7s. they are a very sexy car that has a bit to boot. but most of the distaste has rooted from previous bad experiences, which are now unfounded. they can prob stack up well in GTR catorgory, but the GTR will come out on top (dont hold me to it!). if you can afford it, go for it!
https://www.sau.com.au/forums/topic/53419-rx-7/#findComment-1050252
I almost bought one of the 2nd Generation RX7's i really love the old school 80's shape of them which was inspired by the porsche 944.
I've done alot of research on rotaries over the years and I intend to buy one sometime in the future. There's nothing wrong with them, they're just misunderstood by alot of people, and for that matter mechanics too. This is where poor maintenance and neglect can lead to engines dying early. Luckily though most of the early problems with the motors were ironed out by the 60's/70's.
https://www.sau.com.au/forums/topic/53419-rx-7/#findComment-1050290
i will never step in another rotary again after having had a ride in a 9 second FC (T88 whine, engine noise, wastegate noise, twin big-mutha fuel pumps right behind your head, misfiring during gearshift etc etc).
Although I'm sure the quieter ones are much nicer to drive.
https://www.sau.com.au/forums/topic/53419-rx-7/#findComment-1050481
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
    • Wrong side of sydney for me coming from Goulburn, but you should head along, all ages of Skylines will be very welcome
