spotted a nice clean white S2 in tasmania while i was on holiday :( nice surprise!
also spotted a white S2 while in federation square last night (8pm?)! past flinders st station and was heading down st kilda road!
Edited by atomaly
saw a white RS4 s nice rims and dark tint, parked at Oporto M4 city bound round 3pm, i went tru drivethru was on my way to work. immaculate!
im from werrington,and often around seven hills, hornsby areas as well. i think i have seen u! look back through this thread and i think i may have seen u at Oporto on M4 once a few weeks back
pg 145 :(
ah yes that was me, i was inside eating, i actually saw you go through drive through, nice car man.
yay, but na i didnt see any other stageas..
Spotted Canarygsr again!
this morning at about 7:45am on Nepean highway right near Centre Dandenong road...
Stuck in traffic mate?
i was going the other way!
yeah traffic is bullshit at that time goin that way.. only had to go to southland so wasnt that bad... didnt see u this time either
spotted a dark coloured M35 AXIS this afternoon around 6.30-6.45 at homebush where ryde road meets concord road. damn nice looking car, that chrome grill looks awesome. older looking guy driving, so im guessing not a member here
Not me but the missus......she's learning!!!!
Her email to me:
Spotted: Dark blue stagea wagon, vehicle registration WYF 219, travelling city bound on Whitehorse road at approximate 7.10am, driven by a male in a fluro yellow t-shirt. Same model 250T - same shape as yours. He also didn't have tinted windows on the front.
If only she realised that the windows are factory like that!!!!!
This was spotted today!
The smart ar*e then sent me another email telling me to tell the cyber world of her spotted Stagea's..... and also that she spotted my car in our driveway at 6:50am same day!
spotted a white s2 heading east on the m4 between northern rd and mamre rd about 4:30 this afternoon
was probably me on my way to tafe its been a while since ive been spotted :D
Edited by Space Goat
spotted a white S2 with front mount next to the bp in southmelbourne near crown, i dont remember too much else cause abit boozed from the races all day but im pretty sure i spoke to u and u said ur name but abit to f**ked to remember....... hope i find u hehe.. it was an RSfour, thats all i remember
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
