Maximum noise..
GFB (Go Fast Bits) BOVUS MAXIMUS..
It has twin trumpets and is probably one of the loudest around.
But at 10 psi it may not be the best option.. these are mainly used on ABOVE 15psi applications. They cost about $320.
I had a GFB Mach 1 on my old RS turbo liberty and it was pretty loud.. they cost about $270 new.
Check here..
GFB SITE...
You could also go for Turbo smart but I am not a big fan of those.. they are over priced and not the best quality in my opinion..
Obivously you could spend more and go for a JAP brand like BLITZ but they are going to cost more than you are willing to pay.
Here are some pics of the GFB Bovs..
GFB Mach 1
GFB BOVUS MAXIMUS
PLEASE NOTE: with these atmo venting valves, your car will start to back fire and run rich and sometimes stall because your car has a air flow meter like all the other skylines..
GFB also make a HYBRID BOV which vents some back to the inlet like the stock bov and vents the rest to atmoshpere making the psshh sound..
These cost about $330.
here is a pic of the GFB HYBRID BOV..
ANOTHER NOTE: You will get defected and FINED with any ATMO venting BOV if the police check.
see ya..
https://www.sau.com.au/forums/topic/5358-bov/#findComment-82188
Risto
when i was running 10 psi on my 33, i hooked up a second hand but nearly new Turbosmart Type 3 (so called "supersonic") This is said to be one of the loudest around. Even at 10psi it was still nice and loud. They often come up in the trader. Mine cost 200 bucks.
I thought the quality was fine, and they look tough, with a nice fat trumpet. I found that just going up to 12psi makes the thing sound crazy!
There is one for sale in the classifieds forum, as new, for only 280 bucks.. If i were you id buy that. Its also the current shape Anodised housing, they look real nice :uh-huh:
https://www.sau.com.au/forums/topic/5358-bov/#findComment-83572
quote:
im running a bovus maximus and yeah like GTST says my car also runs rich and stalls particularly after coming off boost and slowing to a stop. other than that, the sound is really nice and when i drive past bus stops, the chicks always look.
Any BOV that vents to atmosphere will potentially cause the car to stall coming off boost (its very annoying, when i put my type 3 on, i simply turned up the spring tension and it cured it, as a negative though, it made the BOV quieter at lower boosts, as the spring was now too tight). This is coz they are AFM equipped.
-When you boost up "x" amount of air is sucked passed the AFM, and the computer supply's "x" amount of fuel for that air.
-but when you back off, most of that air is released from the inlet tract, and never makes it to the manifold to mix with the extra fuel provided. The result is a state of temporary richness as the car comes down to idle, which causes the stalling.
Therefore:- vent to atmo BOV's confuse the AFM and stock ECU.
I feel the need to state these facts as it took me time and frustration to figure it out, being new to the turbo game.
https://www.sau.com.au/forums/topic/5358-bov/#findComment-83876
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
